In my search for a 500 gallon tank I found a source for 120 gal tanks, smaller stand up units. THey weigh about 300 lbs each. I can get them for .07 a pound or about $21 each, 5 would be just over $100. I could lay them on their side stacked on top of each other feeding them in series. Insulate the entire group of them together. It would require more welding as each tank would need a fitting welded in it.
This would be a total of 600 gallons, its more of a stab in the dark for the amount of storage needed but I want to be able to run the wood boiler full out and avoid smoldering fires while its idling, its not a gassefier and dont want excessive creosote buildup in the chimney. We have always run our wood stove flue temp around 400-500 deg and creosote hasnt been a problem.
Thoughts??
~ Phil
Thoughts??
~ Phil
