DneprDave said:I got one! The fire goes out and it gets cold! lol
Dave
smoke show said:The Quad Mt Vernon AE has a low hopper warning symbol on the thermostat.
Probly don't help you out a whole lot.
Indy3 said:DneprDave said:I got one! The fire goes out and it gets cold! lol
Dave
That's the same one I use.
smwilliamson said:a diffused photo eye can measure proximity, I thought of calibrating one to measure 18 inches...whihc would then turn on my vac conveying system and fill the hopper! :lol:
tjnamtiw said:smoke show said:The Quad Mt Vernon AE has a low hopper warning symbol on the thermostat.
How does the Quad MV AE sense hopper level? Micro switch or capacitance sensor? Or something else.
Lousyweather said:smwilliamson said:a diffused photo eye can measure proximity, I thought of calibrating one to measure 18 inches...whihc would then turn on my vac conveying system and fill the hopper! :lol:
only problem being that the fines in the bin might be an issue, dirtying the eye
j-takeman said:Lousyweather said:smwilliamson said:a diffused photo eye can measure proximity, I thought of calibrating one to measure 18 inches...whihc would then turn on my vac conveying system and fill the hopper! :lol:
I work on assembly machines. Photo eyes are more troublesum. Yep! Dirty lense is the common issue for improper function.
What works well is a paddle with linkage connected to a micro switch. Rock solid if installed in the proper location. Could be easily added and it can be made very safe using a low voltage switch. Add an idicator light were visible and you've got a warning system.
Much less painful than my present system. The "dong" noise is OK, Does hurt the ears. Its the physical pain involve after I hear the noise! Switch to an aluminum pan, But still painful. I think she can swing it faster with more velocity! :red:
SmokeyTheBear said:j-takeman said:Lousyweather said:smwilliamson said:a diffused photo eye can measure proximity, I thought of calibrating one to measure 18 inches...whihc would then turn on my vac conveying system and fill the hopper! :lol:
Ah, you have the Wife O Stat model cast iron skillet annunciator, warrantied for life. Just not yours ;-) .
j-takeman said:SmokeyTheBear said:j-takeman said:Lousyweather said:smwilliamson said:a diffused photo eye can measure proximity, I thought of calibrating one to measure 18 inches...whihc would then turn on my vac conveying system and fill the hopper! :lol:
You have one too? ;-)
SXIPro said:Check and fill in the morning, check and fill at night.
mikkeeh said:Has anyone come up with a device to let you know when the hopper is getting low on pellets??. My stove is in the basement...and occasionally I forget to check it. A reminder sure would be nice.
