Mt Vernon, M55, and dealer questions
parallax1
10
Upper Valley, NH
I've been studying this forum, and am just amazed at the wealth of information and generosity of information sharing.
Now that you've been properly buttered up, I've got a few/lot of questions to ask.
First question - anyone living in the Upper Valley area of NH/VT? I've seen post after post about people saying the most important decision may be based on the quality of local servicer... would love some feedback on Home Comfort Warehouse.
After reading a lot of posts, we went to the showroom, set to love the M55 stove (the one with the Vermont Castings exterior). However, the display unit took at least 10 minutes to light. By that time there were pellets falling out of the burn bin. The agitator would come on, quite literally, every 10 seconds. And the motor for it was surprisingly loud. After 20 minutes of fiddling, a new sound appeared - a rather loud hum, seemingly from the auger motor. The guys could not figure out either. The unit was only installed 2 weeks ago, so no one there had much experience with the unit, and didn't know whether the noises were normal or not.
Then they suggested I check out the Mt Vernon. Similar size, similar price, and they said that they have had good results after some growing pains about 5 years ago. They also said that it used a DC motor instead of AC, which resulted in quieter operations. Indeed, the unit was incredibly quiet, and seemed to be putting out a lot of heat with a fan that was decidedly quieter than the M55 (ignoring the motor noise issues). Shortly after they started this one up, they started up an Enviro Empress. The Empress seemed louder too...
To make this message even longer (sorry), let me give you more info about the application.
- 3000 sq ft house. The airflow is... questionable... and our expectations are that we would be happy if it did a pretty good job saving oil rather than replacing all of the heating needs.
- It is most likely being installed in the movie room. This is at the end of the house, rather than the middle. We could put it in the dining room (center of the house) and probably spread heat better, but we would really like to see fire. We like fire.
- Because it is in the movie room, keeping sound low is critical.
- Our priorities, in order are: 1. Quiet 2. Effectiveness 3. Looks 4. Price (as long as all are within the same range). I'm in the timber business, so will probably always be burning wood pellets, so don't care too much about fuel flexibility.
You stuck with me so long, thank you. Now here are the questions:
- Anyone familiar with the M55... is this a common Gen 1 problem, or was I looking at a bad unit/bad installation? Is there a way to keep the agitator from cycling every 10 seconds? Is the motor pretty loud?
- Mt Vernon - I am nervous about the thermostat... I liked the idea of just setting the burn to, say, a 3 and leaving it alone. Having a thermostat as the only control seems risky. Does it work pretty much flawlessly? When it reaches target temperature, does it turn off and need to re-ignite, or does it just cycle low to high fire? What about if it is at one end of a house and you are trying to move air to the other end... is there a way to have it just burn steadily at a given rate? Can you just set it on "medium speed" and forget about it? Is there a manual backup, or just the wall unit? How far away can you put the wall thermostat? I understand that it shuts itself off every 4 hours to clean out the burn pan. Does this result in a lot of wasted pellets? Does it actually turn the fire off & restart itself (more igniter wear?)?
Comparing the two
- Both promise to be able to use higher ash pellets with auto cleaning... is that true?
- Any significant difference in daily maintenance between the two? Periodic Maintenance?
- My wife and I both think the M55 looks better when cold. My wife likes the "circle of fire" in the Mt Vernon better, but I like the wider fire in the M55 better. Who is right?
- Any significant difference in efficiency?
- Seems like the hopper on the Mt Vernon is much better. True?
- Is my impression that the Mt Vernon is quieter, even if the M55 were in tip top shape, true?
- The Mt Vernon is rated for more BTUs, and seems like more heat than we will need. Is that a problem?
- It seems that for a very small difference (after 30% tax incentive) we would step up to the M55/Mt Vernon class from the Empress. I figured better to be overpowered than risk being underpowered for a NH winter. Am I missing something?
- Either have a much better warranty, or more important, warranty response?
- Niether would ever get hot enough to make steam from a pot on top, right?
- Looks like the M55 is easier to clean, everything just drops into the ashpan pretty much? Mt Vernon looks like you would need to vacuum out the middle?
- Now that I've been doing more research, it seems the two most common problems are frequent igniter failures and problems with the cleaning cycle getting stuck. Are those still issues?
- How fast do they suck down the pellets?
- Is there anything I should be asking that I'm not thinking about?
Sorry to be that guy new to a forum and asking a buncha probably dumb questions, but I guess I'm that guy and all I can do is thank you so much for your help!
This is an interesting thread!! I'm sure Pelletdude in CT will want to chime in on this one. I'm personally very interested in the M55 multi-fuel insert. From what Pelletdude has posted on this forum he thinks quite highly of the M55 Enviro.
Winter is Coming!!!!
AR
I am on my 2nd full year with the AE. It is a very good stove and has served me well. I did have some problems with lighting corn, but that was fixed when I modified my burn pot, but Quad has done this to the new stoves. You are going to burn pellets so you are ok there. The igniter housing has been improved to reduce lighter failure, but I have not yet replaced an igniter. If you run it on auto mode it will run longer and not shut down as often because it throttles itself back to a lower setting as it reaches the set temp. I have not had any problems with the thermostat. It also has two settings for the convection fan, this allows you to set it to a quieter setting if you are watching tv in the same room. I have mine downstairs in my family room and it heats the upstairs back bedrooms nicelly. I have a 2000 square foot bi-level home. The thermostat can be run up to 100 feet away from the stove using 20 guage three wire thermostat wire, I have my thermostat upstairs back at the bedroom hallway, about 75 feet from the stove. My autoclean works well, I just lube the rails occasionally with hi temp di-electric grease. I do agree that the m55 fire looks probably more like a wood fireplace. I believe both warranties are pretty much the same. Make sure you have a good dealer who knows how to do service on them. I burn a 40 pound bag per day in mine. With a 3000 sq. ft. home neither will be oversized. Hope I answered most of your questions, good luck and enjoy. Post pics of your install when done. :-)
If you are burning pellets the AE is a dependable unit. As has been said it had issues the first couple years but gradually the problems have been solved. The big thing to me is when it goes through the dump cycle it slows up before the actual dump then has to go through the start-up process again to get back up to speed. If you are are trying to wring all the heat you can get out of it this can be a problem.
One nice thing about the AE is the capability of being able to run it off a 12 volt battery. if you have a power outage this could be a important option.
I think the igniter will be a weak point in that if you get two years out of one you will be doing good. I liked it for the ease of cleaning but the small ash drawer was a problem for me. Then I had that cast iron baffle replaced twice because it cracked.
In fairness I got everything fixed under warranty then sold it to people who burn only pellets. They told me they ran it nonstop for the first year with no problems.
Its like flying by wire with no knobs to turn manually. You are depending on the thermostat to run the stove for you. If you have problems you need a good dealer.
One hint is if you buy one and have problems take the cover off the thermostat and replace it. That sometimes will keep the stove going.
Since quiet is your first priority, check out a Rika integra ll if you have a dealer in your area. Made with ball bearing motors and advertised as "whisper quiet." They are quality stoves that can burn different grades of pellets.
The AE is nice and quiet for sure. I have worked on them and I think the combustion blower is broken unless I get really close and can see the end spinning. combustion blower literally makes NO noise at all.
You can just run it if you want, set it to manual, and set the temp to 90, it will run until you stop it (or it hits 90 F !)
Any other questions on the AE, I have ripped them totally apart and put back together again.
I have an 08 mt vernon AE and have not had any problems to speak of.
burning pellets 98% of the time and never straight corn always mixed.
its about 12 ft from the tv and noise isnt an issue.
I wouldn't hesitate to buy another.
noise level and multi fuel capable were top priorities for us.
can't comment on your other choices. sorry
Thank you for the help so far. Sounds like a few people have the Vernon working pretty well lately?
Any folks familiar with the M55 having similar problems to those of the demo?
Anyone had good or bad luck with Home Comfort Warehouse in White River Junction?
Trogdor, I don't have a M55 but if you look back in Pelletdude's post, or do a search for M55 on this site you will see some discussions about this unit. I too thought about the AE since it does have quite a lot of BTU's. There were many issues with this unit and I still will side with the M55 Multifuel since I don't think the AE is really a true corn burner or multifuel unit. We live in a grain area so we like the flexibility of a multifuel unit. There is another reason I don't like Quad that I really don't want to beat over and over in this forum but it's the fact that they have transfered their assembly to China for many of their units. I would prefer to support a US or Canadian assembly line. Even if they use some foreign parts at least their employing people to do the assembly.
Having said all of that, I'm still running an old Quad CB1200 that I plan to sell and buy a real multifuel unit. Hopefully the M55.
My 2 cents worth.
AR
About the placement of the stove. I don't know if your movie room has a projector or not but if it does you will need to make something to block the light from the flame or your picture will look foggy.
That is a really good point, and I don't know why I didn't think about that.
Thanks for the suggestion to search for someone's posts specifically, instead of a generic M55 search that might help. I will say that I have heard back from the dealer, and he confessed that he is calling the distributor about the problem, because he said if the stove was actually that loud, there was no way he was going to be able to sell any. That seems contrary to what others have been saying about it, so perhaps it really is just a defective unit...
Thanks for the info!!! Please keep us informed what you hear about that particular M55. I'm really curious what the distributor has to say about this "Loud" unit. Pelletdude didn't have anything bad to say about the unit he runs at his home nor the ones he has for sale.
Thanks,
AR
Thanks,
AR
That's what I had thought too, which is why I am eager to see (and hear!) what they find with the demo unit. I also wonder if it is just possible to turn off the agitator completely, or at least turn down the frequency to every few hours instead of several times a minute - if I use good pellets, I would assume I wouldn't need it to run so often.
Now I'm really going through angst - the whole point of the stove was to make a nice warm movie room (and house) and be able to see fire (did I mention I like fire). But it probably makes more sense to move it to the middle of the house and heat the whole building, especially since fire flicker against the movie screen might be dumb. In which case, we won't be staring at fire!
Oh the humanity!
Not using the agitator kinda defeats the purpose of the multifuel advantage. If you want a whisper quiet stove that does only pellets. The Napoleon NPS45 is super quiet and a fellow member geek has just bought one. It has a purge cycle that ramps the combustion blower up on shutdown and every 60 minutes during the burn. It helps blow the burnt ash out of the burnpot and into the ash pan. No agitator noise. Not sure I would burn any standard grade pellets in it, But will handle the Premium and Super Premium pellets. If I wanted a stove that sat right by the TV. That would be my choice.
And the price is much less than a multifuel stove. Something around the $2200 range!
I may have mentioned this before and sorry for repeating if I did. If you really want a good multi-fuel unit, there is one the St. Croix Auburn that is rated at 40,000 Btu. Now this unit is a manual ignition but has 5 speeds and runs off of a thermostat. With the tax credit, you can get a new one for around the $2,000 range and possibly with some of the venting. Go take a look at all the stoves if possible. I'm sure you can find a dealer from the St. Croix website. Between the Enviro and the St. Croix and others, I'm sure you'll find a good unit. Lots of great advice on this forum.
AR
I'm going on my third season with the Mount Vernon AE. No problems so far. I use automatic mode most of the time, which keeps it running almost continuously (without need to reignite). I've had no issues with needing a new igniter (whereas a friend who has a Harmon has had to have many new igniters). I have the Mount Vernon AE insert. It doesn't get hot (I believe that was one of your questions). It has a quiet and normal mode for fans. You may want to find out what the setting was when you saw the Mount Vernon. We typically operate on quiet and the stove is in the same room with the TV -- no problems with sound, but if you're looking to heat your entire house, quiet mode may not be appropriate since normal pumps out a lot more air. We also liked the battery back up option in case you lost power. For the cost of a marine battery, it's a nice option.
Cleaning is easy -- take a few minutes a week. Pellet usage will very based on size of house, insulation, geographic location. I'm in CT, and heat my first floor of my house 1700 square feet with my Mount Vernon. I used two tons of pellets and my house is well insulated with 2x6 framing. I heat my second floor with heating oil which. Lowered oil usage by 600 gallons/year. A friend of mine has a Harmon Accentra with less BTUs -- same size house. The Accentra is challenged on a 0 degree day and he turns on his oil furnace. I've had no problems with this stove on a 10 below day keeping my house warm. I don't think you want to go with less BTUs if you're in New Hampshire.
I love this stove, and am glad I bought it -- and with heating oil now at $2.70 a gallon and going up, I'm even happier.
Thanks for the reply Daves (or is that Dave S?)
Can I clarify (sorry, I'm a little slow) - in automatic mode, does it actually do a clean sweep of the pot every 2 hours, or is that something that you can set it not to do if you are running good pellets? Or does it do the sweep, but somehow not need to reignite - some part of the fire stays lit or something? Sorry, I'm a little slow on the uptake sometimes...
Auto clean is driven by pellet type -- I found this in the forum which are approximate times. The unit will shut down, but the fan keeps running (so it will still blow leftover heat) -- I think autoclean takes about 2 minutes.
hardwood pellets every 2.5 hrs
softwood pellets every 4 hrs
utility pellets every 1.5 hrs
It does a shutdown cycle, auto clean, then starts back up. It will use the ignitor when it starts back up.
I have an M55 and can answer a few of your Qs. During startup the agitator runs with the auger motor for several minutes. If the unit is in "Premium Pellet" mode then then agitator will only run about once an hour for a min or so (constant on), after startup. If the unit is set to the other modes "Regular Pellets" or "Multifuel" then the agitator runs when the auger motor runs, a very short duration every few seconds. I believe this is right...been a while since I tried it. But yeah you can defiantly hear it, maybe since the rest of the stove is pretty quiet on low. I find that light up times can really vary, if you prime the unit by throwing a handful of pellets into the pot before startup it lights in a couple of minutes. The agitator does work really well, I've gone probably through a half ton before touching the pot out for any reason, and then it was just to take a peek, it didn't need cleaning. I usually just need to clean the glass. I do wish I had more control over the convection blower to crank up the speed at lower heat settings.
Trogdor said:
First question - anyone living in the Upper Valley area of NH/VT? I’ve seen post after post about people saying the most important decision may be based on the quality of local servicer… would love some feedback on Home Comfort Warehouse.
ok I'll bite. Since you asked it twice. Personally, I do not know the rep of this place. I
did a google search and a few other review optimized searches and really found nothing. BBB member since 2009. HPBA member since 2008. Very poorly optimized website. That said...
Here are some ways in which you can weed out poor service.
Do they install in housse? Doo they have NFI pellet certified installers? Though this cannot guarantee anything, it shows a level of ownership which will translate into staying power, which is very important years after the sale...and also somewhat separates those who want to "SELL" first and "SERVICE" later.
I respect the whole entire process as a "SERVICE" and I hope they do too.
Call Bill Mathewson, President, (802)295-8778
IMHO, go with the M55.
Thanks,
that gives me some things to think about... I appreciate the help & the research. Sometimes it is just as important to know the right questions to ask, ya know?
