Hello all,
I have a Lopi Yankee pellet stove for the past 20+ years. The stove works very well with little issues. One that has arisen is that the auger jammed again, during the coldest time of the year in NE Pa. It did this last year as well several times. I loosened the auger and let the pellets exit the stove. Tested the auger motor and it spun as it should. It is now working again but I fear that it will clog again. I admit this year I used a half ton of Tractor Supply pellets. They kept clogging together and did not burn fully. I tried Home Depot stove chow and they worked fine for almost a ton burned. Now the auger jammed. Could pellet quality cause the auger to jam? Is there anything to do or clean as I go to prevent this?
Thanks for any suggestions as it is in the single digits lol.
Regards,
Kevin
Regards,
Kevin
