Quick introduction - had installers replace an old wood stove with a new (Hearthstone Phoenix) and an ICC Excel chimney.
The chimney goes up from the first floor through the support box then offsets and up through the attic and roof. It goes up through a corner of the master bedroom closet which was never enclosed but I'm now remodeling the entire master suite (moving the closet and bathroom walls around) and the chimney will be enclosed.
![[Hearth.com] Need help fire caulking stove chimney to pass inspection [Hearth.com] Need help fire caulking stove chimney to pass inspection](https://www.hearth.com/talk/data/attachments/226/226168-87b3b51be4c6ae2fbd149324129b876c.jpg?hash=MPiXbalfdu)
I just had the inspector come for framing inspection which is the last thing I need before sealing up the walls and he didn't pass me because there's gaps around the chimney that need to be "fire stopped". I tried to ask what would be the proper way to do that but he basically said whatever the manufacturer says is supposed to be used.
I'm having trouble figuring out how to properly do this. The stove has been installed for over a year and when I have a good fire going the upstairs chimney gets too hot to keep my hand on. I read through the ICC Excel instructions but there's nothing about draft blocking or fire stopping. It does say you can frame up to the support box so I do need to fill in the gaps at the floor with subfloor which is easy, I just don't know about the ceiling.
I'm also worried that when the chimney chase is completely enclosed and air sealed it will get absurdly hot inside. All the ICC Excel instructions have is this:
![[Hearth.com] Need help fire caulking stove chimney to pass inspection [Hearth.com] Need help fire caulking stove chimney to pass inspection](https://www.hearth.com/talk/data/attachments/226/226169-73c13ea6df60ea977556edf3d8bda367.jpg?hash=yhcPprSp3_)
(Page 9) (broken link removed to http://icc-chimney.com/c/icc/file_db/docs_document.file_en/XLUSA-II_2012-01.pdf)
The only thing in the instructions is:
It seems like that would apply to the gap between the chimney and radiation shield in my picture below.
Here are the two areas that need to be "fire stopped":
![[Hearth.com] Need help fire caulking stove chimney to pass inspection [Hearth.com] Need help fire caulking stove chimney to pass inspection](https://www.hearth.com/talk/data/attachments/226/226171-fac1870902ac69279ee998d0a9cfd104.jpg?hash=CI7tmPTwiI)
Any recommendations or products to search for would be much appreciated. Thanks!
Do not fill the air space around the chimney with insulation or anyother material. Do not fill the factory built supports or radiation shields with insulation. Insulation placed in this area could cause adjacent combustibles to overheat.
![[Hearth.com] Need help fire caulking stove chimney to pass inspection [Hearth.com] Need help fire caulking stove chimney to pass inspection](https://www.hearth.com/talk/data/attachments/226/226170-5167749da077d0b6f76f7bb5b2d478a9.jpg?hash=U9Ze-XOafJ)
