My Pacific Energy summit wood stove had a blower motor give up this winter. The fasco motor was a single speed with a factory installed reostat. The new oem replacement motor from Facso is a 3 speed motor. I bought a 3 speed switch at the hardware store and rewired the stove. Now the lowest speed is about the same as the highest speed on the old motor. I would like to slow all the speeds down a little. The motor guys on the net say reducing the voltage to the motor alone is not good for it. They say Typically when you want to regulate the speed of any A/C or D/C motor a variable frequency drive is required. When you lower the voltage you need to lower the frequency also. I can not find an inexpensive controller anywhere. I think my previous two blower motors failed early due to the fact the cheap little reostat supplied by Pacific Energy was just lowering the voltage and it contibuted to the motors early deaths. (about 3 seasons each)
Any one got any ideas?
thank
Mark
B47120 Centrifugal Blower
115 Volts
4 Pole Motor
3 speed
60 frequency
1360/1100/830 RPM @ free air
1.95 amps @ free air
thank
Mark
115 Volts
4 Pole Motor
3 speed
60 frequency
