New Pellet install and question about smell
Mike16W
22
New Mexico
I am new to pellet stoves and have installed a Harman P35i insert. This week is the first time I have had time to try it out and I have a minor smoke smell in the room. Is this normal or should I check the connections, etc.
Thanks for any help
Thanks for any help
If you have a wood smoke smell you have a leak. Start looking for it.
If it is a chemical, paint smell it is the normal cure the paint smell, it will stop when the curing is completed (this requires a good high temperature burn).
There should never be a smoke smell from the stove inside the room you had it installed in.
Where your stove is brand new, I would be surprised if it is anything other than the burn in smell. I bought my Harmon P68 four years ago. I remember calling the dealer with complaints similar to yours. The dealer said it is just burning in, give it some time. I did and that was it!
Tom C.
Thanks for the replies. I am going to air the room out and then see if it still smells. If it does, I will check the connections and how good the stove slides up against the exhaust gasket.
Also make sure to crank it up! Need to "cure" the stove to stop the New Smell Stink....
Thanks, It's getting a little cold in the mornings so it gives me an excuse to crank it up. Love the heat and the fire.
