My troubles started a couple of weeks ago. I was at the tail end of a 25 bag run of some ashy GT's and I noticed the firebox had a lot of smoke in it, especially whenfeeding pellets. Enough to where I could see black smoke coming out of my outside exhaust. That continued after I switched to MWP softwood. I clened the stove thoroughly the following weekend, although I forgot to clean the ESP (CRS syndrome). The stove still had a lot of smoke, but not as much. This past week I noticed the firebox was covered in very black ash, including my ceramic logs. Friday I thoroughly cleaned the stove again, this time including the ESP (it had a heavy coating of ash.. I checked all the holes in the burnpot, vacuumed under the burnpot, checked the venting, vacuumed under the burnpot again. After this, the ash went back to it's normal gray, and I figured all is well. Today I noticed my oak was connected to the stove very well, so I secured it better. I noticed a couple of hours later, the black ash is back. So I obviously have an air flow problem, but I can't figure out why. The kicker to all this is the fire is active, not lazy at all. There's no excessive ash buildup on the glass. I currently have my oak disconnected to see if that makes a difference.
What am I missing here? Could it be the ESP is failing?
So Ill will say GOOD LUCK !
