So this idea has been bugging me for a while, mid summer and I real start tossing it around. We've all seen the cheapy china mills for a few grand and even some really nice homemade mills that work pretty darn good, heck the farmer down the way had a heck of a set up. Challenge with the routine mill is it is a pretty darn big undertaking, pushing saw dust through dies at a huge pressure is daunting and even getting quality raw material is hard these days, and then the dies that need replacing every so often and a drying process to boot. That and a hammer mill to get product processable is some case where dust is not available. So, here it goes, bare with me. And this is not a 100% replacement for a true machine made pellet, more of a supplement to supply like the dog and horse food I burn occasionally and cherry and olive pits and snowy nut shells. So anyone have one of the kitchenaid stand mixers with the attachments to grade stuff like cheese? Basically a conical shaped drum with round sharp cut outs around the sides, by pressing a block of cheese down into the side of the drum you get shredded cheese tumbling out the inside end due to the cone shape. By changing out the drums you can get thicker diameter shreds or thinner, length is controlled by how much pressure you bear down on the block of cheese. So why not one of these on steroids for the larger diameter dry oak branches in the back 40? Heck, it'd be a wood chipper that would make pellet sized shreds of whatever wood you put through it, no hammer mill, no saw dust, just the stuff you're putting through a chipper anyway. Screen it and you're good to go, mix it in with your normal supply. I realize it would not be as compressed as pellets (and therfore not s much btu's) and you may need feed adjustments accordingly, and maybe here is an example where hardwood would make a difference over softwood. But us backyard creative burners need something to use that is less than a few grand and able to process normal yard stuff into burnable sized fuel. So who's up for making the first die, just use the kichenaid one for the idea and blow it up some and make it really tough. I've got a side shaft 12 horse ready to turn it and the dry oak and screen! Thoughts gang? I printed this and sent a copy via snail mail, but I really don't think that matters! I 'd be happy with seeing a working model and getting a discount on the drum part!
