Awhile back I rigged up a way to attach a 1000 watt 12vdc to 120vac inverter to the 12v system in our Nissan Leaf EV. It worked nicely during power failures, with enough juice to keep the refrigerator, modem & router, and most lights and A/V stuff working. The 40kWh battery in the EV insured this could last for days. (There's a lengthy discussion of this here: https://mynissanleaf.com/threads/using-the-leaf-for-power-in-a-blackout-my-leaf-to-home.13097/ ).
However, during a power failure earlier today it didn't work so well. Basically, about every 4 seconds the lights flickered once. Any ideas about what might cause this ? It was raining when I set it up - opened the Leaf hood, sat the inverter in there and plugged the 12vdc and 120vac cords in, and then ran the latter to a generator inlet on the side of the house - so things got a little wet. But it doesn't seem like that would cause such a regular pattern to the flickering. I guess later I can dry stuff out good and run another test and see.
