The primary air slide on my F3CB gets scalding hot once the stove is up to temp. It only has a small piece that you touch and slide with a finger when you need to make an adjustment. When I'm smart I grab my stove glove to keep it from burning me, but generally I am lazy and try to get by with touching it with a fingernail or something. And invariably I burn my fingertip (you'd think I'd learn after about 1,500 fingertip burns). I'd like to mod it somehow to give me a slightly larger surface to touch and do it in a way that makes it cooler too. Anybody done this?
The piece that sticks out is about the size of a dime. I would drill and tap it and put a small bolt in it but do not think I can get my drill close enough to drill a straight hole. It doesn't look like the air control will come out very easy either. Quickest fix might be a small pair of vice grips but I'm looking for a more elegant solution... Any ideas?
