Hi All! Hope you are well and warm!
Bought Quadrafire 1000 used 8ish years ago. Starts and runs for the most part. Every once-in-awhile it will not start and fills the burn pot about 1/2 full of pellets. Sometimes it will go for a couple of days working great, others a couple of hours before the pot fills. It gets cleaned regular. Couple of days ago, this seemed to be happening sooner than usual. I thought that I might have found the problem as I could press on the thermostat case and it would call for heat. Thermostat got pitched. Had a Honeywell and installed it. Went through a deep clean. Stove started normally, then on the next call for heat would fill the pot and not fire. WTF. Ok, time to really check stuff. Vacuum line not blocked, thermocouple looks ok, and since it would start and run, snap switches probably okiedokie. Exhaust pipe clean and door sealed proper ( put new rope in spring when we quit using for the season ). Do not have a lazy fire nor smoke and the front glass stays pretty clean. Opened the lower door and started checking there. Found the burn pot loose and could move around a bit. Tightened up the two short screws that hold the pot down. While further checking the burn pot, found one of the screws in the pix at the bottom of it. Ok, this is an issue. Further checking showed that there are two of those screws and were just sitting in the holes outside of the burn pot. There is nothing underneath that they attach to. It apparently has been this way since I got it. Guessing here, and suspect that when I vacuumed around the pot it sucked one screw up into the hose, then when I went to clean the inside of the pot, it dropped out of the hose. So the first burning question is: What the heck are those screws for?
Well, that solved the problem of filling the pot immediately. I am back to the every once-in-awhile problem now. I don't want to shotgun parts as that could get spendy. Could the vacuum sensor be having issues? Ideas please.
Thanks
Thanks
