We have a Quadra fire 1200 pellet stove we had done an annual clean out and after that the control board would not work we replaced the control board twice, thermocouple and ignitor. Everything works in regular mode except for the ignitor is not sending power to it. You can put it in test mode and bypass the vacuum switch and the blower motor and everything works except for the ignitor. We can manually torch the pellets and it will work like it is supposed to including shut down. You can turn it on and everything works except for the ignitor. The control board does not change colors it only flashes 1 blue when you go to start the stove and also the other light is a solid red with no error codes. I even bypassed the vacuum switch and the convention motor and nothing changes. The thermocouple was tested and it went up to 0-30 millivolts. The ignitor was tested using the manual start up and it works but there is no power going down to the ignitor at start up. I ohm the ignitor wires from the control board and it has continuity on both sides. I appreciate any help
