RE: Air compressors
firefighterjake
19,588
Unity/Bangor, Maine
I know this topic has come up in the past . . . but I've finally decided that after way too many years of dealing with my tankless air compressor which takes forever and a day to fill up any tire, inflatable, etc. and is next to useless in doing anything else that I would like to get a decent portable air compressor.
After perusing the various threads here and looking at various vendor sites I came across this . . . and would like some opinions.
http://www.amazon.com/Makita-MAC700-Big-Bore-Compressor/dp/B0001Q2VK0/ref=cm_cr_pr_product_top
Planned use would include filling up tires on the cars, trailers, etc. and perhaps running some light air tools in the future such as finish nailers, etc.
I like it. I have had a lot of Makita tools and been impressed with every one. I like the fact that its an oil bath compressor with a cast iron cylinder. I wouldn't buy any compressor that didn't have those two features.
Jake,
You're gonna go from a tankless to a 2.6 gallon? Do you think that'll be good enough? I've got the Craftsman version of this http://www.sears.com/shc/s/p_10153_12605_00902725000P?prdNo=5&blockNo=5&blockType=G5 and it's ok for nailers, but it needs to refill constantly if using to blow things off, fill big tires, etc. If you're not going to actually be moving it a lot, look at something with a bigger tank, like this: http://www.sears.com/shc/s/p_10153_12605_00916642000P?prdNo=23&blockNo=23&blockType=G23 or the horizontal if you prefer--they're both very portable, but will give you more air.
S
An air compressor is like the battery drill, how did i get along with out one.
The small portable ones come in real handy,
for the money it will be a great improvement.
You'll wonder why how you got along with out one.
For what you plan to use it for, should be fine, not a continuos duty one though
Contractors use them very hard, usually see the ridgid or dewalts on job sites with multiple air outlets.
If I can put my 2 cents worth in here. Stay away from oil less and direct drive compressors. I had a nice 5 HP Craftsman, but when that thing would come on you could not even stay in the garage while it was running.
Find a nice built driven compressor.
I have no personal dealings with this compressor but it seems like it got good reviews.
http://www.harborfreight.com/air-to...-cast-iron-vertical-air-compressor-67847.html
Ended up buying it after reading lots and lots of reviews . . . I think for my needs this should work fine since I've borrowed similarly sized pancake tank compressors in the past and was able to do everything I wanted to do with them. Thanks for the feedback.
I was looking at the same one. I was lured by Makita's reputation for quietness. However, I ended up getting a Black Bull 4-gallon 2-hp compressor from Tractor Supply. It is an oiled compressor and while it is loud I'm happy with the lower cost Black Bull.
For what you want it should be fine.
Dont plan on running any die grinders or the like off of it though. I have a 35 gallon in the garage, and a pancake for the small indoor jobs. I got the pancake for free!
pawn shops can be a way to really up grade in size.
The harbor frieght compressor is the one I have, had it for four years no problems so far.
