Secondary combustion in wood furnace
Gearhead660
1,192
Southern WI
Planning to put a Royall wood furnace in my shop. Thinking of ways to make it more efficient/burn cleaner. Add secondary combustion tubes/air? Think I recall hearing about this but wanted to see if anyone has done it successfully.
Getting good secondary combustion is a very very fine-tuned thing. Retrofitting could be difficult as most older stoves didn't consider that at all. I'm not familiar with the model you're describing though.
What he said ^ ^ ^
I've played around with adding it...getting it right is not easy...although some models might lend themselves to the mod better than others. Personally, I would buy a model that has it already.
Already have the furnace aging in the shed. Going in one way or another. Its already got a shelf(not sure of actual term) to direct the air/flue gases toward the front then up and back out. Still might play around with some stainless tube. It also had an induction blower. Going to switch that out for a temp adjusting damper.
