Shocking !
Jigger
Burning Hunk
129
Wareham,Ma.
I have a 25-pdvc Englander stove. I would really like to know what's going on with it.I'm picking up static electricity from my stove. But this only happens when I burn hardwood pellets. I recently switched over to burning soft wood pellets and I'm not picking up the charge. I get a spark that jumps out of my finger about an inch long. It's so bad that even my cat keeps clear of me. Anyone else ever have this happen to them ?
Our static electricity gets bad. We never had to worry about it with the oil burner since we have April aire.
We bought a humidifier. It has helped a lot
It happens to us and our dogs, been meaning to get a humidifier...
you have carpet flooring?
Yes I have carpet in part of my house and also hard wood floors. But it does not matter which one I'm standing on. I still get a zap. But I only get zapped if I'm burning hard wood pellets.
Touch something metal nearby first see if the problem goes away. Once you have done that if you still get a spark jumping something is wrong with you or your stove.
You are not getting a shock from your stove , the static electricity is being discharged to the stove from you
Reactions: Pellet_Pete
I very much recommend you get an anti-static spray and lightly mist your carpets and perhaps upholstery furniture. Supposedly a solution of fabric softener and water sprayed on carpets can work as well. Not sure if some carpet cleaners may have an anti-static solution in then or not. Getting humidity up will definitely reduce the static.
http://www.amazon.com/Static-Guard-...1391259236&sr=8-1&keywords=static+guard+spray
Pouring of the pellets into the stove could conceivably create static from the friction between pellets when pouring in a hopper from a plastic bag or bucket and perhaps the softwood and hardwood may have a different moisture content that makes a difference, but the stove itself won't make a difference in the the static between the two types. If you can touch the stove while loading the hopper maybe that might make a difference.
The stoves body should be grounded through the AC outlet connection, so touching the body of the stove shouldn't cause any problems. Touching something electronic may have a different outcome if you put through several thousand volts into it. Simple as touching a button on your big screen TV, computer, or game console for example could potentially destroy or weaken some components that would render the device to a non-working state.
I play guitar and blew out the front end of a guitar amplifier when I discharged a static charge into it picking up a cord to plug it into the guitar. Fortunately it was a simple fix of replacing an OP-Amp, but other electronic gear wouldn't be as forgiving for a fix.
I do not own a pair of leather sole shoes. So it's got to be me. No wonder all the women I know call me hot stuff and yes I do generate more then an inch. I will pick up a humidifyer and see what happens. I'll also spray the carpet with anti static. It can't hurt other then make the house smell good.
Walking around barefoot shouldn't get you charged up :)
Have you tried tin foil
(broken image removed)
Reactions: gengle
