Because of clearances to combustibles the way I am first thinking of running pipe from my stove to a ceiling support is:
Out of the stove use single wall stove pipe to a double wall tee stove pipe. Then attach the double wall stove pipe directly to the ceiling support.
I'm looking at using MetalFab hardware. The ceiling supports come with an adapter to single wall stove pipe, I don't find any listing for a similar double wall adapter. However in the installation manuals, they show single and double wall being used between the stove and ceiling support.
Will single wall stove pipe fit into a double wall tee?
My other option is a heat shield. Is it allowable/acceptable to fasten a heat shield to a sheet rock wall in order to reduce the required clearances?
Do I need to run all single wall or double wall from the stove to the ceiling support, or can it be a mix of the two?
