Just hooked this wireless thermostat up to our Flame FP-45. It is working to the best of my knowledge. Set stove to Thermostat setting and programmed the unit, set the wall mounted thermostat to 75 while room temp was 71 and the stove kicked on and is running.
My question is this while the stove runs and heats the room to 75 degrees and as the stove adjusts the heat settings to get up to temp will the heat settings visibly change on the stove? For exampe I have heat settings 1 - 6 and whichever heat setting it is on there is a little red light below the heat setting that illuminates. While it is on right now and I am assuming getting the room up to temp the light remains illuminated on heat setting 1 ---- does this mean that it is only on the lowest setting??
Hopefully I am making some sense in trying to explain this.
