St criox versa grate
bbfarm
708
wisconsin
Just wondering if anyone else has this problem.
The little paddle that moves back & forth in the bottom of the burnpot on the versa grate - sometimes we can't get it out to clean the burn pot and other times it pops right out for us.
Is there some kind of trick?
I don't want to force it.
The motor and cam move the grate rod, if the cam is all the way back, then you can remove with no problem. When the cam is to the front that is when the grate is below the igniter tube.
Both of those answers make sense - thanks.
So basically don't force it, and remove it when able for easier cleaning.
You can cycle your stove on and off to move the grate to the right spot...
aaaarrrrrrrggggggghhhhh!
why can't I ever cut and paste an entire quote!
When I shut my stove down for cleaning, I open the right hand door and watch the cam. When it's at the most rearward position, I hit the "off" button, and the VersaGrate stops there.
Failing that, after the stove cools, I leave the door open and (try to) start the stove. The VG motor will run while the stove is checking for vacuum. The stove will then shut down with a #2 error. If the grate hasn't moved enough, repeat as necessary.
When you're ready to really start the stove, just close the door and start normally. Works for me.
Try highlighting the desired text, then release the mouse button. I then get a balloon that says "quote Me". I click it, and the text shows up in the reply box.
I did just that and got the above ^.
you can also turn the motor by hand,
