Problem - The stove runs very, very hot! I can't run it on Level 3 for too long or it will shut down and "smoke out". So, I am running it on Level 2 and it still runs too hot, IMO. In the past I have run it on level 4 with no problems.
Stove is very clean. The room fan has been removed and cleaned as well as the exhaust fan, etc.
Here is what I have diagnosed so far. There are two wires going into the HLS. One wire controls the auger and one controls the room fan. It looks like the room fan is only running on the low setting causing the stove to run hot and eventually overheat.
The HLS is the manual re-set type and the button is currently in the out position. Per the manual, it should be a closed switch (I assume this means pushed in) When I press the button on the HLS it won't stay in. It will remain in the out position. Also, when I press it in the room fan will kick into a higher gear and blow faster but that also kills the auger.
Per the manual - " This is a “Normally Closed” switch and is part of the Fan limit control. If the High limit switch trips several times, the problem in the Stove must be diagnosed before the Stove is put back in service, (Defective Room Fan, dirty Room Fan, defective Fan Limit Control or possibly a bad Control Board)"
Is there anyway to test the HLS if I pull it out? Also, not really sure how to trouble shoot the Fan Limit Control. Any suggestions on that?
Thanks!
Thanks!
![[Hearth.com] St Croix Afton Bay - High Limit Switch [Hearth.com] St Croix Afton Bay - High Limit Switch](https://www.hearth.com/talk/data/attachments/115/115869-7a1983936c87e9e48802e301e13eb001.jpg?hash=hIcFRpgPb2)
