URGENT need small piece high temp fiber insulation
pybyr
2,300
Adamant, VT 05640
Hello all-
in regards to my other thread about the grease spill that got into the gas cook range's insulation [link to thread below], I succeeded in disemboweling the range down to the level at which the fiber insulation layer is-- and can remove all the saturated fiber.
This leaves me needing a piece of 1/2 inch thick 21 by 27 inch piece of high temperature flexible fiber insulation ASAP, preferably at a reasonably low cost.
ASAP because the oven is down for the count in the mean time and even the top burners will be usable only on a makeshift basis
Started digging around McMaster-Carr's website but would appreciate any other suggestions
Thanks in advance!
The original misadventures of grease spilled into the top of the gas range:
https://www.hearth.com/econtent/index.php/forums/viewthread/90357/
You can buy kaowool on ebay. I have bought insulation from both McMaster Carr and from Ebay.
Swedishchef said:
What about Roxul?
Andrew
Thanks (and thanks to everyone else also)
Can't find Roxul in 1/2 inch thick. Also not finding other options in 1/2 inch thick in small quantities/ sizes that won't be a bust to ship....
Thanks
In case this helps someone else, I ended up being able to source a relatively small piece of Kaowool at a reasonable cost through this supplier (below). Should arrive tomorrow...
www.anvilfire.com/
