I have another thread about our chimney lining/insulation project but thought I'd post this specific question here in case others are looking for the answer, too
We're lining an interior masonry chimney with SS liner (not technically necessary but we're doing it anyway.) We do not NEED to insulate the chimney, but plan to use Kaowool at the bottom block off plate and also stuff some down the top of the chimney as far as we can reach.
We're considering also filling the rest of the chimney with Perlite of Vermiculite. I have found several types, sizes, and grades. A local masonry supply place sells VERY FINE perlite for filling masonry walls. I would rather use a coarser material that's less likely to sift through teeny gaps we might miss.... the horticultural type -for seed-starting- is much coarser, and also easier to get locally. Is it safe to use that stuff?
Thank you!
Stacey
Thank you!
Stacey
