I looking for some advice on removing my washing machine water from my septic system. My laundry is on my first floor which currently runs to the basement and into the drain system. My plan is to run another pipe through the floor and out the side of the house just above the sill plate. My concern is how much does the pipe have to drop (Slope) as it exits the house. I don't want the pipe to exit higher than needed since I am exiting the front of the house. Is the flow from the washer strong enough to push the water outside even if the pipe is level? I'm planning on keeping the exsisting drain system intact if it ever needs to be returned to the original configuration.
