Replaced my old wood stove with a new Jotul Oslo last week. Still learning the ins and outs of it but I have a concern with walls next to the stove. It is installed in a corner and the distances from the stove corners to the walls are 12" (right side) and 13" (left side). According to the manual, I only need 9" of clearance with a double-walled stove pipe and rear heatshield. I have the double-walled stove pipe but the installers didn't put the rear heatshield on--said I didn't need it. The manual also says that the rear heatshield does not affect clearances off the sides of the stove. The walls closest to the corners have been getting pretty hot--ranging from can still keep your hand there to have to remove your hand after a couple of seconds it's so hot. Walls are just drywall--one of the reasons we wanted to get the new stove was to get away from the need for wall protection. I'll also note that the clearance for stove with single-walled stove pipe and no heatshields is 13" so even with that scenario, we're close to the allowable distances.
So my question is, did the installers goof by not putting the rear heatshield on? If I have them put the heatshield on, will it help with this hot wall problem? My stove thermometer (Rutland, placed on top corner) shows 450-500 when I'm fully loaded and burning hot.
While I'm at it, one more question. When starting a new fire, I have quite a bit of trouble getting it good and hot using only the air control lever. I have to crack the ash pan door to really get the fire going and then I close it. Seems like you shouldn't need to "cheat" with the ash pan door to get the fire going. I'm burning silver maple--dried for 2 or 3 seasons.
Thoughts and suggestions appreciated.
