Whats this "break in fires"
I don't know that all manufacturers require a break-in fire but I believe it is a good idea whether required or not. From a stove longevity standpoint a series of fires starting very small and getting a bit bigger each time would help cure the materials including any seam cement as well as drive of moisture that could crack porous materials (like soapstone).
The first few fires also tend to cook of any oils or solvents while also curing the paint. There are a lot of unpleasant smells (and harmful chemicals) that should be cooked off by the break-in fire. So it is best to do these when it is still fairly warm and you can leave windows open.
Finally, you are probably anxious to try the stove. Break-ins are a great way to rationalize that without waiting for the cold!
