Hoping to get some advice on why my Whitfield advantage 3 emits a smell of smoke in the house. the stove has been operating normally all winter, recently replaced fire brick and more recently have detected a smoke or exhaust smell in the house. 1st step was to clean this already well maintained unit inside and out. I removed the exhaust blower motor which was in fair shape (although when I "spun tested it it stopped revolving in about 7-8 seconds - I think its the original motor in this great old 1993 stove). When I put everything back together...smell still there. door gasket - check, all pieces in properly - check - Noticed cold air coming from the exhaust side of the stove and after removing the strip of lengthwise insulation, determined that quite a bit of incoming blower air was escaping at the seam identified in the attached picture. After replacing the insulation and running the stove again - definitely cold blower air escaping still. Any help appreciated!
2 questions - would you replace exhaust blower motor at this stage and should I seal the seam in the attached with high heat silicone?
