whitfield pellet stove auger wiring problem???
linklinkone
6
southern nh
hi i just got an older whitfield pellet stove. it does not say what model it is but it looks like a profile model. well i got the stove and the auger was not on it. i hooked it up to my other stove to see if it works, and it does. now the hard part. i dont know the wiring for it to the panel. one black wire has a #5 on it and on the panel there is a blank #5 termial so i put it there. where does the other black wire go????? right next to it????? if so it does not work on this stove. something else wrong???????? please help, thanks.
Here's the manual which includes the wiring diagram for the profile line. Make sure it's the correct model before you play with the wiring though :-)
(broken link removed) Rev E-Profile-stoves(II&OP;).pdf
Good Luck.
link said:
hi i tried that one and its says page can not be found. thanks anyways for the try
From that page you have to go to "Owner Resources", and then "Technical manuals", and then "Stoves". The Profile unit pdf file is at the bottom of the page under "Pellet"
link said:
thank you very much. that did the trick i got the info i needed and the auger is now working. again thanks.
Glad we could help......sometimes you have to "dig" a little on websites. :coolsmile:
