The stove was cleaned thoroughly before using this year, brushing and then blowing the ash traps with compressed air. New door gasket, and tested with a strip of paper. Does anyone have any suggestions as to what could be causing this?
Upon first lighting the stove it seems to work well, but I've noticed quite a lot of unburned pellets in burn pot. by morning half-burned pellets have built up in the pot, and the flame seems to be good The glass also seems to soot up little overnight.
The stove is vented with 3 inch pipe outside there is one 45 short to a short straight through wall, to a T-adapter clean out then 10 feet to a chase cap. Draft can be adjusted almost anywhere same thing happens. Had both fans tested at a shop they said there in good working condition. when I cleaned the stove this year.
Current time stove is running great on low with fan on high, damper closed little, and T-adapter clean out bottom cap off outside. But pellets keep feeding every 7 sec approx at all times even with a big flame during start up. Feeling this could be a bad photo flame sensor.
But seems like the stove is feeding to many pellets with anything I do.
![[Hearth.com] Whitfield Profile 30 Burn Issue [Hearth.com] Whitfield Profile 30 Burn Issue](https://www.hearth.com/talk/data/attachments/144/144522-d595efa0950c15c015cfd7b82a01ec47.jpg?hash=iFZGA6g9vn)
![[Hearth.com] Whitfield Profile 30 Burn Issue [Hearth.com] Whitfield Profile 30 Burn Issue](https://www.hearth.com/talk/data/attachments/144/144574-d8066df66faaf3daacbcef78c3a2d34e.jpg?hash=XV6p-Vf55D)
![[Hearth.com] Whitfield Profile 30 Burn Issue [Hearth.com] Whitfield Profile 30 Burn Issue](https://www.hearth.com/talk/data/attachments/144/144519-93ed3af8d8c277d641f1c6432cd66c47.jpg?hash=JLX78HD4HG)
![[Hearth.com] Whitfield Profile 30 Burn Issue [Hearth.com] Whitfield Profile 30 Burn Issue](https://www.hearth.com/talk/data/attachments/144/144520-e0d89499e93a10d31c7ffec989165b1b.jpg?hash=tIShBRwgtY)
![[Hearth.com] Whitfield Profile 30 Burn Issue [Hearth.com] Whitfield Profile 30 Burn Issue](https://www.hearth.com/talk/data/attachments/144/144521-176d2545789a47ce638a126b78f0a269.jpg?hash=lkNI8QB4RH)
