Hello all,
I have a 28 year-old Whitfield Advantage II insert (S/N: WH-12473) with the old-school dial control panel (Part Number 25250801) that sat unused for probably over 10 years.
Last year, after a visual inspection of the wiring in the back and a thorough vacuuming, I fired it up and everything worked fine for about 45 minutes. At that point, it shut off and I got a smell of burning plastic.
I removed the control panel and found quite a bit of damage, as shown in the photo. As you can see, it burned completely through the PCB pretty much eliminating my chances for a re-build.
As many of you are aware, replacements for this part number are non-existent.
I spent some time last year searching and came up empty. Frustrated, I gave up on this project and began shopping for other options. My hearth is pre-plumbed for gas, but I really, really want to keep this pellet stove as I have fond memories of this particular unit. My sentimentalism won't let me replace the old girl until I've exhausted all avenues for salvaging her.
My question is mainly whether or not the "newer" push-button (part number 12055902) control panels will work with units that are this old. I have read conflicting reports. Some say that these newer CPs only work with serial numbers greater than 18145 (with some re-wiring and disconnect of the Current Sensing Relay), yet I found a guy selling on amazon that claims his 12055902 replacement will work with all older Whitfield Pellet stoves:
https://www.amazon.com/gp/product/B005GW9LSY/?tag=hearthamazon-20
(You'll see in the Customer Q&A that someone asks, specifically, if the two part numbers are interchangeable... the seller says yes.)
SO, can anyone offer and feedback, suggestions, help, links, videos, etc that may narrow my search for resurrecting my beautiful old pellet stove?
Thank you in advance for your time!
-DTJ
![1990 Whitfield Advantage II Control Panel Blew Up (pics) - Suggestions? 1990 Whitfield Advantage II Control Panel Blew Up (pics) - Suggestions?](https://www.hearth.com/talk/data/attachments/233/233662-8c00317e6ce844763e8f53972a3b965b.jpg)
![1990 Whitfield Advantage II Control Panel Blew Up (pics) - Suggestions? 1990 Whitfield Advantage II Control Panel Blew Up (pics) - Suggestions?](https://www.hearth.com/talk/data/attachments/233/233663-86f8e229fb341d132249f891fbb94239.jpg)
![1990 Whitfield Advantage II Control Panel Blew Up (pics) - Suggestions? 1990 Whitfield Advantage II Control Panel Blew Up (pics) - Suggestions?](https://www.hearth.com/talk/data/attachments/233/233664-6f049e5475f795855ee7e5a766a2e12f.jpg)
-DTJ
