Hi folks.
Long time reader. First time poster.
So here's what I have.
I have an external chimney running the side of my house. It's a block chimney. Not clay lined. As far as I can see it's just block.
The chimney had an old stainless liner that had seen better days.
I bought a new flex liner kit. Kit includes the chimney top plate. The rain cap. The 2 piece T. And the flex liner itself.
The stove is a drolet myriad 3. Location is in the basement. There is a hole in the basement wall running into the block chimney outside the basement wall.
I have limited vertical clearance off the top of the stove before I have to go horizontal through the wall.
I'm looking to go up maybe 10" off the top of the stove with single wall into an adjustable 90* and proceed into double wall 6" to the stainless T and then up the flex liner to the top of the chimney.
Basically looking to see what you all see that I don't. I'll attach some pics and some ideas here.
In the pictures you'll see the old setup someone put in long before me. I am currently cleaning out that rectangle opening to accommodate the double wall and have torn out all of the old pipe.
When it's finished it should be a clean rectangle opening through both the basement wall and the exterior chimney. About 9" wide. 15" tall and somewhere around 20" to the back face of the chimney.
![Drolet Myriad 3 Install. Drolet Myriad 3 Install.](https://www.hearth.com/talk/data/attachments/316/316444-47b6c3bdc7ff79ca0f890d7556c6803e.jpg)
![Drolet Myriad 3 Install. Drolet Myriad 3 Install.](https://www.hearth.com/talk/data/attachments/316/316441-cde9bca5feee7ef05462f27d7098839d.jpg)
![Drolet Myriad 3 Install. Drolet Myriad 3 Install.](https://www.hearth.com/talk/data/attachments/316/316442-524615847938a17ec5596a411912f44b.jpg)
![Drolet Myriad 3 Install. Drolet Myriad 3 Install.](https://www.hearth.com/talk/data/attachments/316/316443-a51833a34dfde580b0c246894c2e8414.jpg)
