Hey all, I just finished remodeling the nova 2 I've had for a couple of years, I tore out the hearth, drilled a hole through the brick, and laid down some tile. Really chip and joanned it up! I'm looking for some guidance on installing a cold air intake
- This is a basement / garden level install that vents into a masonry chimney
- I'm wondering if there is any point in having a cold air intake. It would potentially just be a 1 foot section of 3' pipe going straight out the back of the stove and through the fireplace cover I made, see pic (plywood + lots of foam in the back .... I do plan on adding some fireproof insulation to that plywood cover and to the fairly low ceiling). I have a liner installed, so I suppose, ideally, the cold air source could be the draft around that liner 30 feet up at the top of the chimney.
![Garden Level Cold Air Intake Garden Level Cold Air Intake](https://www.hearth.com/talk/data/attachments/324/324237-0fd49a609048a3b07df858e408053d53.jpg)
- The cover itself feels pretty well sealed, but I imagine I would have to seal the upper pipe hole too (see pic), lest the CAI draw from the room itself rather than through the chimney? Maybe furnace cement? Intuitively I'm not quite sure where the air would come from. Would the majority come from the chimney hole 30 feet up, or would it all basically just come from the much closer gaps around the cover and the pipe hole?
![Garden Level Cold Air Intake Garden Level Cold Air Intake](https://www.hearth.com/talk/data/attachments/324/324238-8c883024f1a783782558f2fc5b6eba90.jpg)
- Is there any point in throwing an elbow on the CAI and running the pipe a few feet up the chimney at all?
Thanks!
Thanks!
