Hi, last year I got this wood stove. This is a cast iron model approximately 120 Kg (260 pounds).
It has 3 windows (unfortunately there wasn't much single windowed options here in Turkey). One on front 2 on sides. Actually it even had one in the back but prior to ordering I told them to replace it with cast iron as it was optional.
The back part which is removable, looks like a double walled structure. It has 10 holes in the firebox part but you can't see the anything. The holes don't just go out of the stove. On the exterior of wood stove, back side has 2 venting holes. Again you can't see the firebox from the outside. So my guess is it's double walled. I used a hair dried at full speed to test if it took air in, and yes it did.
There is also a secondary air intake on top of the glass.
The shape of the stove is rounded by sides. The back and front isn't same sized. So i realised the baffle (which looks cast iron around 3mm) isn't well insulated. Because it's a square while the stove isn't a square. And some smoke actually runs form the sides. I ordered 8mm gasket and i will insulate it soon.
Now my question is this stove has a taller firebox than models I have seen on the Web and YouTube. The baffle is really way above. And also there is a good distance between the top of the stove and the baffle (around 10cm~). Would it give secondary burning?
If I had the skills I would add a stainless steel tubing to the baffle and drill the back of the stove.
This model doesn't come with firebricks as its already very sense cast iron, i thought about adding firebricks to the side windows as they are not small. To increase overall firebox temperature to achieve secondary burning.
Or i could add fire bricks to the back side and try to drill the bricks so that the vent holes can deliver oxygen by negative pressure.
Does it make any sense to add fire bricks? I will add pics with measurements on them.
My set up is there is 1.55cm of pipe goes up then there is like 35cm of horizontal pipe which connects to a 304L SS 90 degree elbow flue and it goes 7m SS flue up in a bricked chimney. It's not a liner, 0.4mm SS flue with a wind blocking hat.
The draft is phenomenal. It's a single walled flue but it has bricks around it. And the top 6 meters is well insulated... There is just 70cm of flue sting naked without insulation. But whether don't go below - 5C here.
I burn hard oak seasoned. But when I run out I will probably buy briquettes made from saw dust. They are a bit expensive but i can't really deal with bugs from wood. I risked enough.
Wish it was easy to store wood in an apartment.
flamestove.com
This is the thing but my sides are glass. I will ask for cast iron parts.
Sirius Star Yeni Döküm Soba
![flamestove.com](/talk/proxy.php?image=https%3A%2F%2Fflamestove.com%2Ftr%2Fimage%2Fcatalog%2Fimage%2Fslide-bg-flame%2Fflamestove-favicon.png&hash=9ab4e6441963102d4d37be93a26be397&return_error=1)
