For all of you out there wondering about the MF Fire Nova 2 I figured I would post a review of it here. Disclaimer, this is my first wood stove so I do not have anything or any experiences to compare it to.
Search for a stove
After extensive research I finally settled on the Nova 2 for a few reasons. First, it fit my space well and the ability to convert it to rear vent was what I was looking for in my application. I also liked the idea of a big viewing window and the 26% tax credit will definitely be a plus come tax time. I considered a woodstove insert but I wanted to avoid having to use a blower to distribute heat and liked the open look that a hearth mount provides.
That being said at first I was a little hesitant about the purchase due to the fact that MF Fire's website does not contain a single negative review. Personally I find that a little suspicious. After speaking to a local installer/dealer who said that they had good luck with them so I decided to pull the trigger.
Install
I installed the wood stove myself as follows. A 13ft piece of 6in double insulated flex liner was fed down an exterior masonry chimney. It then passed through an insulated blockoff plate to a 6in tee that I connected to the back of the stove. The flex liner runs almost perfectly straight down from the top of the chimney through the blockoff plate without any large bends etc in it. The Nova 2 sits off the back wall of the fireplace about 16inches placing the majority of the stove out on the hearth. Up top the flex liner is connected to a plate with a 4ft piece of class A pipe running out the top giving me a total height of 17ft. MF Fire recommends a minimum of 15ft for this stove. Please see pictures below of the install. Disclaimer* but after the stove was installed the mantal, bookshelf, etc were removed.
The burn conditions
I have had several fires in the new stove so far. Temps outside have been in the mid 40s during each burn. Fortunately, here in Michigan we have not gotten any freezing weather yet. I am burning seasoned Ash that I cut and split myself.
The Good
-After the first 3 fires the smell of curing paint seems to have vanished. I would recommend you open up some windows when you fire this thing up for the first time
- The veiwing glass does stay relatively clean. If it does happen to fog up, once a strong fire is going again the glass seems to clean itself effectively. That is with the exception of the edges of the glass that do tend to stay slightly fogged after prolonged slow burning. The big window really does make for a great viewing experience.
-The stove is super easy to use. With only one lever to flip I spend very little time messing with the stove. I throw wood in, flip the lever, and walk away.
The Bad
-I have found that this stove must be down to coals before reloading. If I go to open the door when their are any flames I cannot stop smoke from rolling out the front of the stove. I tried all of the tricks recommended on here (opening a window, making sure all fans are off, open bypass, crack door, etc) with no luck. I contacted MF fire in regards to this and they suggested I remove the bypass restrictor plate. In doing so I found the smoke situation improved. I can open the door but if I mess around with any of the burning wood I get smoke out the front again. Of course I do not have anything to compare it to so perhaps a little smoke out the front of a stove is not unusual.
Other Info
-I did contact MF Fire in regards to what temp the stove should not exceed. They told me it is "extremely difficult to overfire the stove" and that it is not uncommon for their stovetop meter to be maxed out for a period of time. I also have a Midwest Heath temp guage on the stove and it has hit temps of 750 degrees after I loaded 4 large logs. I do not have a thermal reader to confirm a "true" measurement.
- I did attempt an overnight burn. I stated with a pile of coals raked towards the front of the stove. 4 large splits (7in or so) were packed tightly together in the rear of the stove. I put the wood in at 10:30pm. Per my security camera the flames in the stove died out around 1:30am. The bed of coals were glowing strong until about 3:30am and when a woke up at 6:30am there were enough hot coals to light a fire with small kindling and some paper. There were not a ton of coals left and dont think I could have just tossed a medium size log on and let it go. That being said during the night my house got significantly warmer (70 degrees up to 80 with the thermostat being in the middle of the house). Without any air controls on the Nova series more wood means more heat. Being new to this I am not sure if that is standard for stoves to significantly warm up during an overnight burn or not. I wish I could keep an overnight burn without significantly adding heat to the house.
Conclusion
I am satisfied with the stove and am happy I bought it. I have wanted a wood stove for years now and finally had the opportuny to get one. That being said if I can get this smoke issue completely figured out I would be golden.
If you have any questions or feedback on my setup please feel free to reach out. As I said, this is my first time having a woodstove and am always looking to learn. That being said, I look forward to being warm this winter!
![MF Fire Nova 2 Review MF Fire Nova 2 Review](https://www.hearth.com/talk/data/attachments/300/300764-12f8eea1810396895578a23bfda1c3aa.jpg)
Search for a stove
Install
The burn conditions
The Good
The Bad
Other Info
Conclusion
![MF Fire Nova 2 Review MF Fire Nova 2 Review](https://www.hearth.com/talk/data/attachments/300/300760-05f6e76124c5d9f11a7d5a22c929b8dc.jpg)
![MF Fire Nova 2 Review MF Fire Nova 2 Review](https://www.hearth.com/talk/data/attachments/300/300761-3b3c7497ea1c59f906aed43a27d5a7a6.jpg)
![MF Fire Nova 2 Review MF Fire Nova 2 Review](https://www.hearth.com/talk/data/attachments/300/300762-8b1a3d818d4376c5670113afa4c233ef.jpg)
