Hi all!
I recently purchased an Englander pellet stove off facebook market place and have installed a 3 inch double walled smoke pipe that goes out the wall. When I purchased the pellet stove, I noticed it is very dusty in the back and was full of ash in the chamber. I cleaned it out as best as I could for now and ran it. I clicked start up and it started up normal, I then raised the Blower Speed and Heat range to 5 & 5. After about 30 minutes, there is a plastic smell coming from behind the pellet stove. We removed the back panel after shutting it down and the smell stops when it’s shutting down. Nothing seems to be melting, and pellets burn perfectly (as so it seems). I’ve ran it 3 times now and on heat and range settings set to 1 & 1, it still has a plastic burn smell after 30 minutes; filling up the air with this smell. We were not given a manual and the people who sold it to us and do not have any recollection of this smell happening..
The last time I ran it, I ran it on heat and blower range at 8 & 9 and the plastic smell happened, and eventually the pellets stopped pushing out and the flame went down and there were pellets on the plate hot like coals but there was no smoke or anything. I am also wondering if this is because it shut down from over heat or if the tray had too much ash even though it burned for 30 minutes..
We also do not know the model of this Englander and have looked all over for a model number. Nothing!
Anyways, if anyone has advice, thank you so much for your time! I have pictures attached.
(There is also some sort of fiber glass and tinfoil contraption in the back. I forgot what it is called but could this be potential issue?
Thanks
Also No error codes have showed up.
![Used Englander Pellet Stove - Plastic Smell and in Need of Model identification Used Englander Pellet Stove - Plastic Smell and in Need of Model identification](https://www.hearth.com/talk/data/attachments/267/267536-b477dc93c09727be2b3650db9b04fba1.jpg)
Thanks
![Used Englander Pellet Stove - Plastic Smell and in Need of Model identification Used Englander Pellet Stove - Plastic Smell and in Need of Model identification](https://www.hearth.com/talk/data/attachments/267/267525-b0d1137459a09c7325d51818afd8b8ab.jpg)
![Used Englander Pellet Stove - Plastic Smell and in Need of Model identification Used Englander Pellet Stove - Plastic Smell and in Need of Model identification](https://www.hearth.com/talk/data/attachments/267/267526-b7ce51ab604e96b9173b2b92e6d658a5.jpg)
![Used Englander Pellet Stove - Plastic Smell and in Need of Model identification Used Englander Pellet Stove - Plastic Smell and in Need of Model identification](https://www.hearth.com/talk/data/attachments/267/267527-2d3e8f3d443bc4e903cf2b2541bbb11a.jpg)
![Used Englander Pellet Stove - Plastic Smell and in Need of Model identification Used Englander Pellet Stove - Plastic Smell and in Need of Model identification](https://www.hearth.com/talk/data/attachments/267/267528-17eecae456847cd647809f44c28eb790.jpg)
![Used Englander Pellet Stove - Plastic Smell and in Need of Model identification Used Englander Pellet Stove - Plastic Smell and in Need of Model identification](https://www.hearth.com/talk/data/attachments/267/267529-dd1a346c3ab8c5d9d1bebca040acea6b.jpg)
![Used Englander Pellet Stove - Plastic Smell and in Need of Model identification Used Englander Pellet Stove - Plastic Smell and in Need of Model identification](https://www.hearth.com/talk/data/attachments/267/267530-22315b98b244d870496b9439a0e9d1e0.jpg)
![Used Englander Pellet Stove - Plastic Smell and in Need of Model identification Used Englander Pellet Stove - Plastic Smell and in Need of Model identification](https://www.hearth.com/talk/data/attachments/267/267531-a5b5bacece550d16482db4c81b8b214b.jpg)
![Used Englander Pellet Stove - Plastic Smell and in Need of Model identification Used Englander Pellet Stove - Plastic Smell and in Need of Model identification](https://www.hearth.com/talk/data/attachments/267/267532-53bbc58fd33b10db2a0e7b2a988bb7ad.jpg)
![Used Englander Pellet Stove - Plastic Smell and in Need of Model identification Used Englander Pellet Stove - Plastic Smell and in Need of Model identification](https://www.hearth.com/talk/data/attachments/267/267533-6a7910be52cc5b4c386fbbb87541c35e.jpg)
![Used Englander Pellet Stove - Plastic Smell and in Need of Model identification Used Englander Pellet Stove - Plastic Smell and in Need of Model identification](https://www.hearth.com/talk/data/attachments/267/267534-845084ce5affeeaef29245472f1eb107.jpg)
![Used Englander Pellet Stove - Plastic Smell and in Need of Model identification Used Englander Pellet Stove - Plastic Smell and in Need of Model identification](https://www.hearth.com/talk/data/attachments/267/267535-c5e198473a1602306d9b326bb93738f1.jpg)
