Hi all, I have a late 1950's fireplace that was the original heat source for the small home that was later added onto and now has central heat. There is a gas hookup inside the fireplace so we are going to have a gas insert put in and I'm trying to figure out if we can close up these vertical brick vents at the floor and above the firebox? If we can we would likely be looking for reclaimed bricks to try and match the old ones. I'm seeing conflicting information so I just want to be sure.
Thanks!
![Can I seal these upper and lower vents if I convert to gas insert? Can I seal these upper and lower vents if I convert to gas insert?](https://www.hearth.com/talk/data/attachments/326/326933-41ea0abd40e5067187c807a856dcebdb.jpg)
Thanks!
