Ouch! Our previous furnace was like that, my wife would make me set an alarm to wake up and feed the furnace. I would go to bed late (around 11 pm) so the furnace would still be going at 4am when I woke for work. I never got to sleep in on the weekends, or I would wake to a cold furnace and house. Since we've tightened up our home and replaced the furnace with our current model, it's not an issue. Last night I loaded at 9pm and at 7am it was 71 in the house, temp was 11 degrees. Not to mention the old furnace had a 6.5 cuft firebox, which I would stuff every night. We now load less than half in the current furnace.So I traveled up north for some skiing with the family this weekend. Funny thing... even though I was staying at a hotel, I still woke up at 3:30 ready to reload the fire box. [emoji15]
Yep, I use to do the same thing when we had our wood stove. For about 2 - 3 months of the year I didn't sleep very well.So I traveled up north for some skiing with the family this weekend. Funny thing... even though I was staying at a hotel, I still woke up at 3:30 ready to reload the fire box. [emoji15]
Loaded up last night around 11 on about 3” of very hot embers. The heat output didn’t skip a beat, first floor at 73. Headed to bed at 11:30, outside temps were in the lower 20’s. Woke up at 5:30 and the first floor temperature was down to 67 degrees, 64 upstairs.
This is what the fire box looked like.
To be honest, I have no clue if the Tundra II would look the same.
I'll post a picture of what the tundra ll looks like after 7 hours... usually 7 hours later my house is still 75f maintaining that with just the coals in the box.
Thanks! I am trying to break down things into 2 parts.
Part 1, firebox and hot embers.
Part 2, supply/static pressure. Is my duct system causing heat loss or inadequate supply.
Does this make sense?
Also your supply ducts might have an impact... but you do have 2 -8inch ducts and are pulling return air off your basement ceiling?
Just so we are on the same page... if all that and HY-c engineer can't get you 10 hour burns your done with the dead horse?
Mr. Pellet burner, What is HY C doing for you , anything?? Call me an idiot but I bought an Fc1500No smoke shield?
No smoke shield?
I applaud your patience and effort you have put into this up to this point, but I think the old saying "You can't make a silk purse out of a sow's ear" applies here.Correct... if they leave and I am still getting the same out of this unit, I am done with the suffering
Little over 3 hours into the burn. Loaded to top... only with 16-18 inch splits.
That's called "boost air"...it has a 1/4" hole that blows a little air right on the base of the fire to keep things rollin after a reload, mainly once the main intake damper closes...basically, it just helps keep the primary fire going a bit. Many "tube type" stoves have a version of this.
