A few more weeks in, running with the cat probe, and I have to say...why didn't I do this sooner?!
You're able to tell right away, or in a very short time, exactly how the burn is reacting when you make air adjustments. No more guessing when you don't have a cat glow--you can tell if the cat is burning by what the probe is telling you. As Todd mentioned, you might have 1000* on the cat probe, but it isn't glowing yet. Or the cat temp might rise or fall in response to an air adjustment you make, whereas without the probe you are just guessing if the cat's not glowing. You know it's burning though, if the probe is telling you it's well above 500, and you can verify that it is by looking at the stack, although you don't have to.
We're getting nights that drop to about freezing so I'm still loading the stove full sometimes, even though it may burn down to just a few coals left during the day. I've been generally getting the probe up to 450 or better before closing the bypass, then the probe temp will rise quickly as the cat begins to burn and I'm routing flame heat to it. Now, stove top temp may only be a little above 100 at this point and it sure is nice to have the probe to tell you what's really going on.
I'm sold on this new way of running my cat stove and I highly recommend the use of a cat probe if you want a great aid to burning. I sure won't be going back to the old way, now that I've seen how well this works!
Hey, wait a minute Todd; I think I saw an analog probe in your connector pipe in one of your pics. How come you didn't keep the digital thermometer/washer sensor, or get a shorter probe to use in the pipe of the Jotul secondary stove that you now run? 😯 Then again, I suspect that precise temps and instant feedback wouldn't be quite as important to running a secondary stove, and you may go more by what your eyes are telling you, since you can see what's going on at the tubes..
![embarrassed ;em ;em](/talk/styles/default/xenforo/smileys/embarrassed.gif)
