I have a PE Summit and can attest to the fact that it will heat my 2 story 2500 sq. ft. home quite well, even in sub-zero temps, but requires quite frequent re-loads when I need to really crank out the BTU's. The Summit is rated as capable up to 3000 sq. ft in the original brochure, however I note that they no longer post this figure on their website.
NON Cat P.E. Summit
Room Size 3000 sq. ft. (from original brochure)
Burn Time (max.)10 hrs.
Firebox Size 3.0 cu.ft.
Heat Output Cord Wood 99,000 BTU
http://pacificenergy.net/products/wood/stoves/summit/
I am looking at the new Hybrid/Cat stoves (I'm considering a new stove for longer burn times than my Summit provides) and am trying to get my head around why the Large 3500 and Very Large 5100 Regency Cat/Hybrid stoves suggest 2250 sq. ft heating capability, versus the Regency F3100 non cat stove is rated at 3500 sq. ft., which is about the same capacity as my Summit?
QUESTION:
Will I be sacrificing the sheer power/ max output heating strength when it gets very cold, in order to gain low consistent, loooonger burn times, if I make the switch to a large Cat/Hybrid stove?
NON Cat Regency 3100
Room Size 3500 sq. ft.
Burn Time up to 10 hrs
Firebox Capacity 2.9 cu. ft.
Maximum BTU 80,000
http://regency-fire.com/Products/Wood/Wood-Stoves/F3100.aspx
Regency Cat/Hybrid 3500
Room Size 2250 sq. ft.
Burn Time 24+ hrs
Firebox Capacity 3.0 cu. ft.
Maximum BTU 75,000
http://regency-fire.com/Products/Wood/Wood-Stoves/F3500.aspx
Regency Cat/Hybrid 5100
Burn Time 30+ hrs
Firebox Capacity 4.42 cu. ft.
Maximum BTU 80,000
http://regency-fire.com/Products/Wood/Wood-Stoves/F5100.aspx
FWIW, Blaze King's claimed square footage heating capacity looks more promising but no sign if the max claimed BTU is up to the Summit's level.
Blaze King, King
Heats 1,500 – 3,000 Square Feet
40 Hour Low Burn Times
4.32 Cubic Foot Firebox
51,582 BTU's/h constant output for 12 hours (they seem to not provide a Max BTU output)
http://www.blazeking.com/EN/wood-stoves.html
NON Cat P.E. Summit
QUESTION:
Maximum BTU 80,000
Burn Time 24+ hrs
Maximum BTU 75,000
Burn Time 30+ hrs
Maximum BTU 80,000
Blaze King, King
