Hi all,
I purchased my pellet stove used a couple years ago. it has been working pretty well and i am happy with it, howver this year i have decided to replace the gaskets on the door and glass as they leaked a bit last year and they were a little crusty in places. i have a couple quick questions.
1. everywhere i look it says 1/2" rope for the door. the gasket that was on there is much bigger. when i pulled it off, there was silicon inside the groove also. i scraped it all out, but the 1/2" only fills the groove and doesnt seal. should i just get the same size that was on it before? from pictures i have seen, it is a larger rope, possibly 3/4" or so.
2. from online it says 5/8" x 1x8" for the glass gasket, i got that and it is wider than what i had. thinking of finding 3x8" x 1x8, which is what it looks like. or should i stretch the 5x8" tight when i put it on, that will make it so it doesnt show.
3. from the pictures i have see of the air vents inside the ash trap, mine looks a bit different. there are 2 directly in the middle, one pipe on the left that sticks out about an inch, and 1 hole just to the right of it. now the pictures i have seen, they are both open. the pipe one that sticks out a bit on mine has a cap on it.
i dont have a picture of mine right now, but if you look at this one, it is identical. except there is a cap on the pipe vent on mine, not open like this.
http://www.butkus.org/whitfield_operate/whitfield_cleaning/cleaning0003.jpg
anyone know why this would be? the stove has worked fine, as far as i know, with it capped like that.
btw, this is the model i have, with the one piece glass.
http://woodheatstoves.com/images/Whitfield Advantage 3Tfs.jpg
thanks!
thanks!
