Looking at making my own baffle gasket similar to Hog, while the stove cools down, any idea on the dimensions? Thanks in advance.
oldspark said:So how much you selling them for? :lol: I installed 2 of the PE standard ones last summer and they are already broke and hanging down.
madison said:As hog stated,cut it longer than you think once you start messing with tying the frayed ends you will need the extra length. If it is too long once tied, just leave the extra on the left and right side of the vertical channel. It takes a bit of squeezing to get the pin back in, or, leave the pin out for a bit and wait for the baffle weight to flatten the gasket enough to get the pin in.
if you see any flat gasket material, ie window gasket, it would be fun to try that material as well. and report back if the flat gasket can be tied successfully.
SKIN052 said:No idea of the cost of the original gasket but even if it were $1.00 it would be a rip off, the suck. Old Spark if you were any where near by I would make you a lifetimes worth. I have enough material to make at least 20 of these.
SKIN052 said:I did find an old welding blanket and said, why not Took out the baffle and measured the hole and added about 1/4" lip all the way around. Cut out a piece about 2 1/4" by by 3 1/2" with some tin snips and gave it a try, seems to work very well.
Hogwildz said:While the baffle gasket is there for a reason I am sure. They do not seal that great due to the front area not having anything there to support then gasket. The gasket tends to sag there as there is nothing under it at the front.
These baffles, at least on the Summit, do have secondary burn holes in the back under that bent over lip on the back bottom of the baffle. So if you see secondary flames fanning out from the back, it is intended to be that way. Most likely to more evenly burn the load and burn the gases that accumulate in the back of the fire box.
As far as eye damage, maybe yes when tinkering with the gasket, but once it is in the stove, it really is not an issue.
Skin, if you have enough and can send me a pc to make 1 gasket, I have some ideas I have been experimenting with with the rope gasket, that I would like to try with the welding blanket material. If yuou have it great, if not, no worries. Shoot me a PM if you do and I will dens you my mailing addy.
And Kudos to you for helping OS out!
I sent someone a gasket I made for them, but can't remember who it was. Wondering how it is holding up?
raybonz said:Hogwildz said:While the baffle gasket is there for a reason I am sure. They do not seal that great due to the front area not having anything there to support then gasket. The gasket tends to sag there as there is nothing under it at the front.
Hi Hogs,
I have never taken the T-5 apart as it was just installed this year but will next spring.. I was wondering what you think about using Roxul insulation to create a gasket.. It's easy to cut and should handle the heat so might make a good candidate for a gasket.. I don't mind paying $3.00 for a gasket but I do mind driving 45 minutes to get to the PE dealer.. I do like the welding blanket idea and will have see if I can locate any..
Ray
Hogwildz said:raybonz said:Hogwildz said:While the baffle gasket is there for a reason I am sure. They do not seal that great due to the front area not having anything there to support then gasket. The gasket tends to sag there as there is nothing under it at the front.
Hi Hogs,
Ray
I have never seen nor handles Roxul, so can't really say. If it looks like it will work, make a gasket and try it. Even if it fails, it won't hurt anything.
Changing and buying a new gasket every year is a pita, and bullshit as far as I am concerned. PE could make a better gasket any day of the week. It is nothing but a money thing on parts. Figure how many folks clean each year and order a new gasket each year x $3.00 = a good stack of dollars.
Hogwildz said:Aside from the baffle gasket, you should not need anything else for years to come. I did the door gasket a few times, mostly my own doing. You know about my baffle gasket adventures. I did the glass gasket cause i scratched the original glass up and got tired of seeing it that way.
The only other mishap was the cracking of the welds etc. I have a feeling that was limited to those certain years productions.
Hogwildz said:madison said:As hog stated,cut it longer than you think once you start messing with tying the frayed ends you will need the extra length. If it is too long once tied, just leave the extra on the left and right side of the vertical channel. It takes a bit of squeezing to get the pin back in, or, leave the pin out for a bit and wait for the baffle weight to flatten the gasket enough to get the pin in.
The flat window gasket does not hold up worth a crap. Tried it.
madison said:Hogwildz said:madison said:As hog stated,cut it longer than you think once you start messing with tying the frayed ends you will need the extra length. If it is too long once tied, just leave the extra on the left and right side of the vertical channel. It takes a bit of squeezing to get the pin back in, or, leave the pin out for a bit and wait for the baffle weight to flatten the gasket enough to get the pin in.
Interesting Hog, did it burn, disintegrate, tear or all of the above?
Kinda think that is over engineering. Not sure where to get thread that would hold up to the heat. and the added thickness will make it a pain in the ass to get the pin back in. I have 5/8" gasket in there now and that ain't working out so great. Still sagging down in the front where there is no support for that portion of the gasket.iceman said:Is it possible to take hog gasket and wrap it with the blanket and sew it? It would best of both worlds and last forever.....
Hogwildz said:Kinda think that is over engineering. Not sure where to get thread that would hold up to the heat. and the added thickness will make it a pain in the ass to get the pin back in. I have 5/8" gasket in there now and that ain't working out so great. Still sagging down in the front where there is no support for that portion of the gasket.iceman said:Is it possible to take hog gasket and wrap it with the blanket and sew it? It would best of both worlds and last forever.....
Just looking to find a material that lasts the longest. So far, its 3 or 4 years for the 3/8" rope gasket.
Some kind of metal gasket wrapped in fireproof fabric would prolly be the way to go. Sort of like a car engine gasket.
