Thru the wall fans
These came up in another thread, so I thought I'd post my experience.
These fans are designed for circulating air from one room to another, perfect for wood heated homes. They are made to pass through a wall into the adjoining room, but the design allows use of flexible duct to allow longer runs. Mine run from the living room to the bathrooms, which were cold and damp. I purchased them from Home Depot online 4 years ago and they do a great job of keeping the bathrooms warm and dry. I placed the intakes as high as possible in the living room and the discharge (fan) at floor level in the bathrooms.
The fans I used are Thruwall brand and come with a two-speed switch, round grilles and attached power cord. I purchased rectangular intake grilles for my installation and the fans are wired directly inside the wall. The power consumption at high speed is 50 watts according to the manufacturer. Once we start heating, I run them continuously at low speed. The noise level is low, but still noticeable enough that Heidi likes to keep the bathroom door closed at night. As a result, the bathroom is warmer than the bedroom for those middle of the night nature calls.
I'm very pleased with these fans and frequently recommend them to people with uneven heating problems.
In the same vein, I installed an 18 in. register directly above my wood stove.
This is connected to 2 registers in upstairs bedrooms allowing convective flow. The upstairs was much colder than the downstairs because of an enclosed stairway with a doorway at the bottom. The house is now much more evenly heated.
MrWhoopee, nice pics and good ideas. I'm working on my installation right now. My house is a raised ranch, about 1050 sq ft all on one floor. My living, dining, and kitchen are all open. I was thinking of installing something like this to pull heat to one bedroom.
I use one to move warm air out of the stove room in partnership with a small fan on the floor pushing cool air back to the stove room down a reasonably long hallway. Without either fan I'm unable to move heat to the rest of the house.
My thru-wall picks up heat directly off the stove and single wall in the stove alcove:
ETA: I went a simpler route and mounted a receptacle up high near the fan and merely shortened to cord. Being in the alcove, you hardly notice the cord.
And pushes it into the dining room:
The little rascal is rather loud though, even on low.
In the summer the stove goes to the shop and I put the bar in the alcove:
Ingenious!! Though, doesn't moving that stove around get a little tiring? LOL Very nice finish work.
MrWhoopee, on your recomendation I bought and install the same fan (thru wall). It works great!
I've thought of something like this for my house. The only rooms I can readily vent to are bathrooms and would only be through a single wall. My reservations are that in the summer the normal bathroom noises and smells could pass through the wall vent into the occupied living space.
I've thought of the same. My solution would be to find a cover for the vents and put them on durring the summer. If nothing else white duct tape trimmed to fit would be a quick and easy solution.
In consideration of these very same issues (and my generally frugal nature), I installed the cheap, noisy vent fans in the bathroom. Call it white noise. :)
have seen magnetic covers for vents
rn
