Storage temp dropping
speedyvt
13
Southern Vermont
Can anyone tell me if there is a way I can turn off the eko 25’s circulator pump once the storage tank is to temperature. My storage gets to the set point of 175 right now, but when my eko runs out of wood the circulator keeps running till the temperature hits 156. I believe that this is sucking heat out of my storage by my boiler acting as a radiator.
You could raise the temp your controller turns the pump on and off. 156 seems a little low to have it come on to me.
The circulator launch temp is maxed out, it will only go-to 160. And the pump launch hysteresis is set at 4deg’s. So I'm not sure if there is a way to isolate the pump to stay off until once the storage tank his its set temp, but is still able to come on it the wood boiler gets to hot.
I'm also curious how this would be done. I've been setting a timer to shut it off, but I'm sure there is a better way.
I have mine set to come on at 170 and it shuts off at 167 I think.
Can anyone think of a reason a reverse acting aquastat hooked to the pump wouldn't do the trick.
One problem would be that once your storage is up to temperature for as long as the circ is running all any aquastat is going to see is hot water until all of storage is mixed down to the low limit. So the pump keeps running and running, doing no good and undoing stratification.
But wouldn't the aquastat allow me to turn off the pump at a higher temperature? The controller on the Eko only goes to 160 I could set the aquastat to say 175 it would then kill power to the pump until the temp rises to whatever I have the differential set at.
How old is your eko 25? I thought most of the controllers will launch at 170 max? This year with my eko 60 I time my burns just right so before bed if the wood is pretty much burned up I just shut the main switch off. If I did not do this my storage water at 185* would circulate from storage back out to boiler(150' away) thru boiler and back until my return water dipped below 170*
Rob
I purchased my eko in October of last year. I understand the idea of turning off the control, but I would rather have the control do this for me. Do you or anyone know of a way that the control could be reprogrammed for a higher launch temperature?
There are a number of controllers out there that will do this for you in a hands-off fashion. I nearly pulled the trigger on a differential/setpoint controller that would have done exactly what you're asking. You basically tell it that once your output temps are within a certain number of degrees of your input temps, you close (or open) a circuit.
I ultimately decided I didn't want to invest the time and money. It also adds another point of potential failure between the boiler controller and the circ pump.
Here is the manual. http://www.newhorizoncorp.com/wp-content/uploads/2011/06/RK-2001UA-ENG11.pdf
4.2. Circulating pump parameters
Circulating pump launch temperature [P144] - temperature of water in the
boiler, which causes start of the circulating pump. Circulating pump works
independently from the control process and is launched additionally in
case of boiler overheat.
Circulating pump launch hysteresis [Ph 4] - this parameter defines what
value should temperature decrease by, below circulating pump launch.
I start my boiler with the launch temp at 165*
When it gets going good above 170* I change my launch temp to 170* my max setting on my control.
I think I have my PH setting at 2 but I am not sure. so when my temp gets down to 168* pump shuts off.
Rob
Thanks everyone for the help. I'll be sure to let you know how I make out.
Rob, I did change the settings that you are talking about on my 25. The max setting is 160 not sure if you have a higher setting because you have a higher output boiler or not. But again thank you for the information. This site has helped me more than anything in getting this system up and running.
This is what I did with my EKO I let a independent digital aquastat control when the circulator turns on and off this way I can get my storage temps much higher before letting the fire go out.The EKO controller still controls the fan.
