Vintage 181 said:www.gameoflogging.com/training
In the October issue of Forest Products equipment is an article about the Chain saw safety Plan. Author is Wendy Komancheck. The majority of the article is about the chain saw safety plan Program at Paul Smiths College...The professor has been teaching the course since the 70's..
36,000 people are treated each year in Emergency departments due to chainsaws..Higher when you include natural disasterss like Katrina.
Eric Johnson said:A bigger saw is not necessarily a better saw. It depends on the application. With modern chain technology, you can get by with a lot less horsepower and probably a shorter bar than you might think.
Personally, I wouldn't consider anything other than a Stihl, Husqvarna or a Jonsereds, and I'd buy it from a servicing dealer.
The helmet will protect your head from getting bashed in or deeply gashed if a limb should fall and hit you on the head. A big limb will drive your head right into your chest cavity, but some protection is a lot better than none. At least the helmet will help prevent stitches and/or a possible concussion. If you need to inquire about the need for ear and eye protection, then you probably shouldn't be using a chain saw in the first place. In addition, kevlar chaps and steel-toed work boots (at minimum) are essential for anyone using any chain saw any time.
Most beginning chain saw operators survive mostly on luck. Read the saw manual and you'll get a good idea of where you should be focusing your attention. Like my daddy always said, with woodcutting, the only problem with on-the-job training is that sometimes they give the final exam on the first day.
Finally, if the Humbolt is your idea of a notch and you have no idea what bore cutting or a barberchair is, then you need to do more research. Google "open-face felling" for openers.
Here's a link:
http://www.forestapps.com/tips/notch/notch.htm
More good info:
http://www.forestapps.com/tips/tips.htm
Eric Johnson said:Hey Craig. What a coincidence. My dad wrote that book and I edited it. They told us it was out of print, but Bailey's must have a few copies stashed away.
I'm really glad you enjoyed it. I still pull it out and read a few chapters now and then. Still go back to Wisconsin every summer and cut pulpwood with the old man, too.
I'm not so sure about a 372xp and a 16" bar and i'll tell ya why. Running a 18" bar on my 346XP and an 18" bar on my 372XP the 372XP is a lot heaver but dont cut any faster in 16" wood. The 372xp turns at 13500 RPM and the 346xp turns at 14700 rpm. Your just haulling extra weight with a 372xp and a 16" bar. Now where the bigger chainsaw will shine is with the bigger bar. Throw a 24" , 28" or a 32" and you are just as well to leave the 346xp in the truck because its out of its league. to me a 372xp with a 16" bar is like a F250 truck with 13" car tires. You also mentioned your ms460 with a 20" bar ? You must not cut over 20 or so " logs ? or are you cutting both sides to make 1 cut ? .......... not coming down on what you use or what you say , just flapping about preferences.MALogger said:I have been reading this thread for a while and I have to chime in. I don't understand why anyone would want to get a chain saw larger than they need. Bigger saws are more expensive, they are heavier and the chance for severe kickback increases with more power and longer bar lengths. I make a living working in the woods using a chainsaw everyday. I use a Husqvarna 372xp with a 16" bar. Also I use a stihl ms460 with a 20" bar. I have a 24" bar which I rarely use. If you learn how to cut would properly you don't need a long bar.
http://store.baileys-online.com/cgi-bin/baileys/2023?mv_session_id=ir6dRm4o&product_sku=17390
Check out this book, It is very interesting if you are into cutting wood. There is a section on choosing a chainsaw. As stated in the book, if your bar is never to short then it is probably to long. The point I am trying to make is get the smallest, lightest high quality saw you can get by with. You can keep a spare bar and chain that is longer than you normally need.
When dealing with large trees determining lean can be more difficult as well as getting the tree to fall where you want it to. I use wedges to drive the tree over in the direction I want it to go not where it is leaning and if you have cut any trees at all you know they usually are not leaning the way you want them to.
And as Eric said the bigger the tree the more severe the damage to you or property or someone else if it goes the wrong way.
A small tree could cripple you or worse imagine what a 40" inch dbh (diameter) monster could do.
The saw Eric mentioned is a perfect choice for cutting firewood. Husky 346xp. Small lightweight and powerful. A comparable model for stihl fans would be the ms260.
Matcho has no place when it comes to cutting wood with a chainsaw!
Be careful and if you are not sure about something get some help from someone who is sure.
Craig
Yogi said:Ok guys, I have read and read and until my eyes hurt!! I think I have made my chice on my next saw, see what you guys think of my idea. I think the Husqvarna 346xp. It is light, has great power on paper at least, and will run an 18" bar easily. I have found a lot of videos and watched them again and again and have been practicing doing bore cuts on small trees, the wildthing doesn't seem to have enough power to do it well. Most of the videos that I have seen came from Husqvarna and the saw of chioce was always the 346xp and usually with a 16" bar!! I was amazed at what could be done with that short of a bar!!
Do you guys think this is a good way for me to go?
bobo said:Hey Yogi you still looking for a saw yet ? I got a very new Husky 346xp I'll sell you if your interested. I really dont like it 3 tanks gas through it.
Bobo
