Thistle said:bogydave said:High quality Chinese steel. :-S
Find an old one at a garage sale, when steel was made to last, not to make a quick buck.
I have 2 mauls, (1 USA, 1 China) one has had 2 new handles, but the heads are still good.
Maybe use a sledge & safety glasses if you have to hit your wedges that hard. Grind em before they send shards of metal flying.
Your gas money to & from the store to get it replaced is costly.
Be safe, no kids around.
Good luck
Yup. Check out local garage or estate sales,flea markets,farm & household/antique auctions,Ebay/Craigslist for great quality older USA made hand tools.Often found at a fraction of the cost of newer inferior made Chinese crap.
I'm happy with my Chinese 8lb maul - it's much better quality than the crap that Craftsman sells. It just doesn't have the Craftsman warranty.
At some point I'm going to get to buying one of Council Tool's mauls - perferably a 6lb and an 8lb, each with fiberglass handles.
These are a good old redneck-made North Carolina product, but they're fairly expensive. Having broken a bunch of the Craftsman 6lb mauls and characterized their crap as prone to breaking a certain way, it'd be interesting to torture test a Council 6lb maul and see what happens.
Of interest on Council Tool's website are on the product description are:
(1) description of the material properties of the head (heat treated to produce a fine grain structure on the bit end);
(2) Rockwell Hardness of 45-50; and
(3) forged head.
The forged head is an interesting feature. Forging aligns and stretches the steel grain; cast steel grains are less organized. You can see where the steel flash was cut off the side of the maul head when it came out of the mold, so the Craftsman stuff appears to be cast steel.
They also encourage you to use their wedges with their mauls as they've designed in an appropriate hardness difference between each. While I use Craftsman wedges with my Craftsman maul, I've found no like guidence from Sears.
It does make sense that mixing and matching wedge suppliers and sledge/maul suppliers is a bad practice. This would explain some of the bad experiences related here regarding wood grenades.
I have not been able to locate comparable hardness information of the Craftsman maul head as yet, but it would be interesting to have for comparison purposes.
http://www.counciltool.com/DisplayCategories.asp?pg=displaycategories&category=73
