Finally caught up with splitting.
Thanks weatherguy. I was just wondering with that much shrinkage just what it was.
The first three row shrunk under 4 feet so i took some from the forth row and topped them off. Im only concerned about it until i get a good yearly average since it is easier to calculate cords when its 4 feet high.
Which brings up the point that most folks always state how much wood they have when the wood is measured green and not after it has shrunk. There can be a big difference.
btw, I've never checked the length for shrinkage. May have to check that one out.
btw said:
Ok this is sad but i have;em. All of the pcs that i have marked have shrunk less the a 1/4 of an inch.
Sorry stil trying to figure out this quote thing.
That's it, I'm leaving this forum! You, Dexter, & a few others oughta go somewhere & start a school on wood storage/stacking, & quit giving the rest of us such a complex.
OK but seriously, that's an awesome job there, & great setup. WELL DONE!!!! A C
Its this forums fault ;lol. I use to just stack it then restack it when it fell over. Then i seen pics of everyones stacks here and thought there was no way i could show mine.
weatherguy, what kind of wood is that?
Definitely not ash. That's amazing to me that wood can lose volume like that. I would have thought the cells would just hollow out once they lost their moisture.
View attachment 65562View attachment 65563View attachment 65564View attachment 65565 Hello everyone.
Well i finally got the last of my splitting stack finished today. Good thing cause i will be bringing in 2 more loads this friday that need split. I was hoping to be closer to 2 years ahead by now but with the mild winter and the ground never freezing put a damper on that plan. All of the wood in pics was cut starting Sept 2011. The sad part about it is the only oak in the stack is the 4 X 4 runners that its stacked on.
HJ,
I thought I was doing a OK job, but your stacks could grace a calendar. Beautiful indeed!
Tim
"That's it, I'm leaving this forum! You, Dexter, & a few others oughta go somewhere & start a school on wood storage/stacking, & quit giving the rest of us such a complex." -AC
This post stole my thunder. Very neat. Way......too.......neat!
That is awesome. What did you use to keep those end posts secure? I'd like to employ something similar on the ends of my stacks, but so far have had to use angled boards connecting from the posts to the base for support.
