New chimney install
patdale
54
MD
Well if anyone remembers my previous thread I had a chimney that was not installed correctly. Today, I had a new one installed.
First I made a new hearth to put the stove on. I put down cinder blocks as a frame and covered in Durock and then added tile. I still need to decide whether I am going to tile the front edge or use stone veneer. I plan to put some sort of stone on the walls behind the stove also. Now it just needs to cool off so I can try it out!
Here are some pics...
Whew, that was a long haul. Congratulations. You will be able to sleep well at night now.
I've never seen a cinderblock support before. What anchors them in place to stop the front blocks from moving if kicked? Are they cemented to the Durock?
I didn't want to use any wood so cinder blocks is what I came up with. I use Loctite Landscape adhesive that is made for block. I used it to secure the blocks to the floor and to stick all the Durock on. There is two layers of Durock on the top. It is very solid and not going anywhere!
Looks good. I like the raised hearth...you will enjoy that feature.
Nice work looks nice.
Raised hearths are the cat's meow. Wouldn't do it any other way.
I am having a hard time grasping your hearth construction. Seems a stiff wind will blow the whole thing away. The durock is glued to a bunch of blocks that are glued to the slab floor? Normally the durock is attached with a whole lot of very substantial screws. Any reason you didn't at least use mortar or thinset? Is that glue rated for high heat?
That adhesive is used in outdoor wall construction, i dont think a "wind" will blow it over. The stuff does not get that hot under a stove do it?
Yeah, the hearth is definitely not going anywhere. I used 7 tubes of the adhesive. As far as heat, there is tile and a layer of Durock over it so I'm hoping its not an issue. I guess we'll wait and see.
I didn't want the mess of mortar or thinset.
Looks awesome!
What brand chimney is that?
I can't really see the offset support too well in the pic, just curious as to who makes it.
Very nice Pat and your hearth is creative using cinder block glued to the floor and the Durock. Looking at the manual for your stove I think you'll be fine as it appears you need ember protection only. If all companies designed stoves this way hearths would be much easier to create..
Ray
I finished the wall, now just need to tile the front and put some sort of border around the rock on the wall. Finally lit my first fire this morning!
Looking good.
Hearth looks super nice.
Is that really the FW3000 ? I have a 2006 FW2700 which apparently isn't as efficient as the newer models. Mine holds 22" logs but is a smaller firebox than the 3000.
Any chance of posting more pics of the inside of the firebox ? I assume it has 3 or 4 steel tubes for secondary burns.
I'm thinking about replacing my pre-epa stove in my basement in favor of either the Englander NC30 or the FW3000. I'm sort of partial to the Century as mine has served me flawlessly for 8 years on my main floor.
Looks great! Just noticed the picture you have sitting to the right. I helped hang that same huge pic of the rope bridge at my daughter's apartment! Really cool pic love the perspective makes you feel like you're right there :)
Ray
The sticker on the back says FW3000 but the dimensions don't match up with what is on Century's website. I think it was built in 2007 so maybe it is an older model. I'll get a pic of the firebox tonight.
Ray
the wife has since changed the color the of the wall so the picture is no longer there. I only need to grout the front tiles, then I'll post a new picture.
Reactions: raybonz
