My Fireview is behaving a bit differently tonite, normally once stovetop temp gets to burn range for the cat, I can close bypass and set the damper to around .75 and flames go away in about 5 min's and of course cat ignites and she cruises through the night that way. But tonight I did the same thing, shut bypass and set to .50, for a long burn overnight and flames die out, but about 15min's in woof, backpuff. So I turn it up to my usual .75.But now I have constant flames in fire box.I can't turn down anymore than this because of my backpuffing. Just wondering if this is normal? The only thing different about tonite is outside temps are just dipping in the upper 40's. This is some of my coolest temps so far. Could this be effecting my stove? Just scratching my head at this point....
