Rika integra insert error ER2
She2dancer
7
SE Mass
We just shut down our stove to clean it out, cleaned it and now we are getting Error code ER2. I've searched the manual everywhere and the error codes are not listed...the only thing it says is that if an error code appears the appropriate problem must be resolved before restarting....but doesn't list what the problems could be.....ARGH!
Does anyone know what the error codes for the Rikas are so we can get heat tonight? Burrrrrrr....
TIA!
https://www.hearth.com/talk/posts/565816/
read through the whole thread and they reference er2 as the High Limit Switch error code. That was 2 years ago so who knows. Couldn't find anything online, hope that gets you in the right direction...or you could pm one of those guys in the thread since it seems like there a few with the same stove. Hope you get it going.
hmmm....interesting, thanks for the info....very strange how it was running fine until we shut it down to clean it. Also very aggravating that the manual doesn't list the error codes (I also downloaded the tech manual - no error codes listed in there either - who has them????) lol....
Nice stove.........
may depend on software # but here is what i have
depends on it the stove is flashing or remains on.
flashing auger off system good...
remains stove shuts down.
i assume stays o9n because stove off.
er2 overheating. i would reset it and see if works
er0 low exhaust gas temp , missing pellets fire out
er1unacceptable config of auger parameters
er3air flow, door gasket, burnpot dirty, intake exhaust etc
er4air flow too low increase fan rpm
if reset doest work try high limit switch........
good luck
high limit is auto reset. the switch is NC (normally closed) any chance that a wire came undone? here is where its located. You can troubleshoot the switch by connecting the two wires together that go to the switch
thank you all for that info! We cooled the stove down, cleaned out the heat exchanger panels and baffles, restarted and it started back up no problems! phew! Thankful you folks are here to help!
Reactions: jgrz0610
She2dancer,
What did you do with your Quadrafire? If you still have it I would be interested in buying some parts from you. Thanks
