Gleason Avery. Ball bearing output shaft, same make that Englander uses now. $74.99
http://www.gleasonavery.com/catalog/pellet-corn-stove-motors.html
Why does Englander put them in their stoves then? I doubt that would be a problem, but the OP could always switch the top auger to the bottom, and put the GA in the top spot.That motor is a intermittent duty style motor, don't you need constant duty rating for the lower auger?
If you mean CCW (counter clockwise), then you'll either have them switch the rotation for you....the stock GA configuration is CW, or you can do it yourself....it's about a 4-5 minute operation, tops.ok good points, will checknration first. its appears to be a right hand motor, auger is turning left as I look in the front door
That's good information.Duty RatingI got this off a motor site. "Duty rating refers to the length of time a motor is expected to operate under full load. The motor may be rated as either Continuous duty or Intermittent duty. Continuous duty rated motors are rated to be run continuously without any damage or reduction in life of the motor. General purpose motors will normally be rated for continuous duty. Intermittent duty motors are rated to be run continuously only for short time periods and then must be allowed to stop and cool before restarting. It is usually possible to reduce the size, weight, and cost of a motor by purchasing an intermittent duty motor. Intermittent duty motors are available with maximum operating times of 5, 15, 30, or 60 minute duties or times. These motors are sometimes used on devices like garbage disposals or air compressors where the motor operates for a short period and shuts off after the job is accomplished and will not be needed for an extended time period."
