More IDs
Jacktheknife
452
Lakota, Iowa
Pretty good haul from the tree dump yesterday, got it processed today. There was a bit of cherry and crab apple (still attached crab apples were a pretty good giveaway) and a lot of mystery wood. Thoughts? Leaves pictured are from that same piece.
More IDs More IDs
More IDs More IDs
More IDs More IDs
More IDs More IDs
More IDs
Jack that last picture is box elder. The red in the center tells that. Maybe some cherry leaves or wild cherry in a few others.
Reactions: Jacktheknife
Thanks, the red was very obvious when I was cutting it. The forth pic has a bright pink ring just inside the bark, doesn't show up as well here.
Does anyone else have any ideas on the others?
Box elder for sure. The others are Cherry.
Not a bad scrounge, then.
